Old 03-16-2023, 12:44 AM
80stang 80stang is offline
Default L78 - recommended distributor date
Hey Folks,
I have been looking for a 499 distributor and located one. The distributor is dated exactly the same as the block stamp. Do you think that's ok or should I keep looking for an earlier date? This pic look legit? Thanks!
More info on my motor:
Heads - late Feb 69
Intake - 3/3
Block cast - 3/6
Block stamp - 3/11
This distributor is 3/11.
Old 03-16-2023, 01:21 AM
WILMASBOYL78's Avatar
Post Dated Components...
Dated components generally are a month or more behind the assembly date of the engine. Cast date of the block may vary wider...in your case the dates are close. My sense is the date should be earlier...the distributor gurus on the site know the 'real dates'. All of the bolt-ons were generally gang run....therefore common dates.
I would look for 'good dates' via PM with the experts...
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 03-16-2023, 10:06 AM
I appreciate the response and that makes sense. Will follow your advice, thank you!
Old 03-16-2023, 12:38 PM
cook_dw's Avatar
cook_dw cook_dw is offline
What's the build date of the car? You can email me at the address (Camaro Data) in my sig.
Old 03-17-2023, 07:00 PM
Kurt S Kurt S is offline
Impossible. The distributor date has to be before the engine assembly date. The distributor has to be shipped to the engine plant (because the beaming technology was inconsistent back then).
https://tenor.com/view/galaxy-quest-...d-gif-12093633
Kurt S - CRG
Old 03-20-2023, 12:07 PM
cook_dw's Avatar
Old 03-20-2023, 03:18 PM
Rumbleguts396 Rumbleguts396 is offline
Just curious on everyone’s thoughts on the stampings on that distributor? Is it a known date? I’m just trying to educate myself. Thanks, Rob
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Old 03-20-2023, 06:09 PM
cook_dw's Avatar
Yes.
Rumbleguts396 (03-20-2023)
