Old 03-30-2023, 06:50 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Looks great - were you able to save the original carpet/door panels, etc. as well?
Jake Dykstra
Dykstra Motorsports
Old 03-30-2023, 07:34 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Door panels & seats are originals and in great shape from what i remember but unfortunately only half the carpet survived and the racoon took care of the sail panels and headliner & firewall pad. If anyone out there has a pair of original sails, headliner or even original carpet for non console car please lmk as I'm about to make an order in the next few weeks.
Old 03-31-2023, 12:00 PM
cook_dw's Avatar
Photos 573 - 576 - Mounting some accessories.
The Following 6 Users Say Thank You to cook_dw For This Useful Post:
1967Z28 (03-31-2023), Dave Rifkin (04-01-2023), dykstra (04-01-2023), napa68 (03-31-2023), olredalert (03-31-2023), RPOLS3 (04-03-2023)
  #174
Old 04-03-2023, 11:36 AM
cook_dw's Avatar
Photo 577 - Are of the drivers door and glass while cleaning. Simple ole glass cleaner, razor blade and a cotton towel.
Photo 578 - Glass after cleaning. Not perfect by any means but its not horrible. I might hit it with the da polisher later on but for now it will work.
Photo 579 - Photo of glass date code. CZ-10 - Nov 67. -10 is explained here on the CRG site. Click Here
Photo 580 - Door assembly after cleaning.
Photo 581 - 582 - Door with original paper reapplied. Note that the door handle mech sits on top of the bracket and the arm will be applied over top of the plastic. 2 small holes were still present in the plastic cover.
Photo 583 - With a little effort and choice words the door panel finally settled back in to its original resting spot. Panel still needs to see a good hot day outside but other than that the panels are in great shape.
Photos 584 - 585 - Decided to change things up a bit and while the column was out (still waiting on my lower bearing which hasn't shipped in over a week and still haven't got word from Groundup if the manufacturer has the dang thing..) it got me thinking about the tach placement. I could go the traditional route and place it on the column or copy the Yenko style and screw it to the face of the dash (wasn't doing that). Then I remembered this weird hole that was previously drilled in the lower center of the dash. I assume for a gauge or some sort of switch but it wasn't done at the factory. Then I saw the screw holding sec flasher and it hit me.
Photos 586 - 588 - Dash assembly after picking up having tools, screws and bolts scattered around.
Photos 589 - 590 - Door glass rolled up and door closed. Also made a video of the door closing.
Door Closing Video
The Following 9 Users Say Thank You to cook_dw For This Useful Post:
1967Z28 (04-03-2023), 67since67 (04-03-2023), dykstra (04-05-2023), L78_Nova (04-03-2023), napa68 (04-03-2023), olredalert (04-03-2023), RPOLS3 (04-05-2023), Woodrock (04-03-2023), X66 714 (04-03-2023)
  #175
Old 04-04-2023, 11:20 AM
cook_dw's Avatar
Photo 591 - Pass side glass date. Dec '67.
Photos 592 - 593 - Ran across one of the earlier photos when I first went to inspect the car after my fathers passing. Dad passed in '06 and this photo was in '10. Comparison photo.
Photos 600 - 601 - Time for the passenger seat to get some attention. Citrus degreaser, fingernail brush and elbow grease.
Photos 602 - 604 - 303 Rubber & Vinyl protectant applied
The Following 8 Users Say Thank You to cook_dw For This Useful Post:
1967Z28 (04-05-2023), 67since67 (04-04-2023), dykstra (04-05-2023), gtomike1967 (04-05-2023), Jims69z28 (04-04-2023), napa68 (04-04-2023), olredalert (04-04-2023), RPOLS3 (04-05-2023)
  #176
Old 04-04-2023, 03:32 PM
Crush Crush is offline
You have some serious patience! Great work
The Following 3 Users Say Thank You to Crush For This Useful Post:
cook_dw (04-04-2023), napa68 (04-04-2023), olredalert (04-04-2023)
  #177
Old 04-04-2023, 09:06 PM
R68GTO R68GTO is offline
I just read through this entire thread Darrell. Great work as usual. I really appreciate your patience, attention to detail, and sharing your methods/techniques with this community. Can't wait to see it all come together!
cook_dw (04-05-2023)
  #178
Old 04-05-2023, 10:26 AM
dykstra's Avatar
dykstra dykstra is offline
That interior is cleaning up nice!!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
  #179
Old 04-05-2023, 10:45 AM
cook_dw's Avatar
Thanks guys. The replies are appreciated. Wrestled the passenger side door panel on. Didn't take a photo of the water shield as its the same as the driver.
Photo - 605 - Door panel
Photo - 606 - Glass adjusted to factory locations. I chose to not blow apart the doors as the glass was still tight and smooth on the roll up & downs. Just re-lubed all the tracks, mechanisms etc and carried on.
1967Z28 (04-05-2023), dykstra (04-05-2023), L78_Nova (04-05-2023), napa68 (04-05-2023), RPOLS3 (04-05-2023), X66 714 (04-05-2023)
  #180
Old 04-05-2023, 12:26 PM
RPOLS3's Avatar
Nice to see it coming together so well.
Jake Dykstra
Dykstra Motorsports
