Old 04-28-2023, 12:33 PM
RamAirBirds's Avatar
RamAirBirds RamAirBirds is offline
I am currently putting back what i assumed to be a "owner installed" cowl plenum back onto my 68 Z28. Have the correct A/C and what appears to be a modified firewall duct...possibly from a Chevelle. This was done way way back in the day and so it needs to go back on. I bought the last made boot a member here had that is correctly seamed together on the bottom. I am curious on both where you got your boot AND are you going to put the factory staples back in place on the AC side. That is the last hurdle I have to do...I have heard they used both Round and Square staples (similar to a box staple). My original Air Cleaner clearly had small "round" holes so this is what i am going to use. I am thinking that the staple used for putting the flaps on the front wheel wells should work. Just curious what you are thinking of doing if anything.
RA
