Old 05-07-2023, 09:04 PM
MosportGreen66's Avatar
Default Year and application of SB oil pan?
Hi Gang, I can’t place it’s origins.
Can anyone help with application and value?
Thanks,
Attachments - The Supercar Registry IMG_5205.jpeg IMG_5204.jpeg IMG_5203.jpeg IMG_5202.jpeg
Old 05-07-2023, 10:38 PM
67since67's Avatar
Exterior is very similar, but not exactly like a '67 Chevelle 327. Inner baffle is stamped different. Small drain plug too. No idea of value Dan.
Old 05-07-2023, 11:39 PM
69 to 74 small block would be my guess.
You can measure the front lip as shown in this thread: https://www.camaros.net/threads/nos-...l-pans.178450/
Pretty sure the Z/28 pan and the L48 pan were the same externally. The Z pan just had the two rails to mate up to the baffle that bolted in.
Old 05-08-2023, 12:19 PM
70 copo 70 copo is offline
Dan,
That's a 283 pan from a mid 60's B Body application.
It was so identified by the seller when I bought the identical pan at a swap 10 years ago all because it had a valuable "A" embossed pan plug in it.
I paid 20 dollars for both the plug and the pan at that time.
I still have it.
Old 05-08-2023, 12:31 PM
New on Flea-Bay: https://www.ebay.com/itm/22533368092...Bk9SR8KKn7X_YQ
Old 05-08-2023, 01:19 PM
I realize the drain plug could have been changed; but through 67 (maybe 68?) I believe the hex on the drain plug would be much larger. Didn't the 9/16 hex started in 68 or 69?
67since67 (05-08-2023), RobR (05-08-2023)
Old 05-08-2023, 04:40 PM
I needed the "A" plug for my 67 pace car. Here is an auction for a pitted example.
https://www.ebay.com/itm/14505776726...Bk9SR66_xcP_YQ
