Old 06-15-2023, 02:36 PM
Crossbreed383 Crossbreed383 is offline
The next order of business after a getting metal work close enough for filler was to prep all the little areas that were an issue.
Someone drilled 12 holes in the body on each side for rubber door guard molding. I also decided to go the route of de-trimming the car to better match a COPO look for a stripped down sleeper.
That meant welding in all the molding holes as well as fixing a bunch of little pin holes in the trunk gutter area as well as some minor pitting in both the front and rear window channels.
Then it was finally time to apply some filler and start getting things straight.
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
The Following 3 Users Say Thank You to Crossbreed383 For This Useful Post:
69M22Z (06-15-2023), dykstra (06-15-2023), olredalert (06-15-2023)
  #62
Old 06-15-2023, 02:40 PM
Finally time for some DTM primer for all the bare spots and then I used some Polyester primer to help not only get things super straight after blocking but it helps seal in any old substrate.
Old 06-15-2023, 02:44 PM
Some more pics
The Following 2 Users Say Thank You to Crossbreed383 For This Useful Post:
  #64
Old 06-15-2023, 02:46 PM
1st coat of Polyester primer
  #65
Old 06-15-2023, 02:49 PM
Guide coat and block time !!!!!
69M22Z (06-15-2023), dykstra (06-15-2023), L78_Nova (06-16-2023)
  #66
Old 06-15-2023, 02:53 PM
The BOSS even helped out with the tedious sanding. My wife helped sand and did all the jambs, and under hood and trunk areas.. She earned a new found appreciation of the old adage.." (The harder it is to sand, the more important it is !) " She's a rock star !!
  #67
Old 06-15-2023, 03:11 PM
Some pics of the wife's jam work and before old door pins were removed /replaced.
  #68
Old 06-15-2023, 03:15 PM
Some more pics before/after final 2k panel priming ...
  #69
Old 06-15-2023, 03:20 PM
More block sanding.....Also in pics you can see tape pieces showing any pin holes/imperfections in panels.
  #70
Old 06-15-2023, 03:32 PM
Final , final prime ,and letting parts bake in sun to shrink since I don't have a booth to bake them in :
