Old 07-24-2023, 09:44 PM
Rumbleguts396 Rumbleguts396 is offline
Default 1969 427 Block Stamp thoughts
Hello all, I found this 1969 427 block available for sale. Casting number 3963512.
Cast date C 12 69. 4 Bolt mains. I can’t make heads or tails out of the pad stamps. Anyone have any thoughts on what this decodes to? I appreciate your input. Thanks Rob
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Old 07-24-2023, 10:06 PM
RPO LS7 RPO LS7 is offline
Tonawanda May 7th assembly date, 7BA = marine application. Not sure about the other numbers.
John
The Following 3 Users Say Thank You to RPO LS7 For This Useful Post:
olredalert (07-25-2023), PeteLeathersac (07-25-2023), Rumbleguts396 (07-24-2023)
Old 07-25-2023, 02:20 PM
DAVE H DAVE H is offline
Seems to be a lot of these popping up lately. Mine is a August '68 cast 270 block, 7BL suffix. I've found a few very desirable engines in the old cabin cruiser type boats in graveyards over the years. Those usually have corrosion issues. The racing boats usually ran a closed cooling system, from what I've learned from researching the sport.
The Following 3 Users Say Thank You to DAVE H For This Useful Post:
olredalert (07-25-2023), PeteLeathersac (07-25-2023), Rumbleguts396 (07-25-2023)
Old 07-26-2023, 08:33 PM
Thanks for everyone's help. I'm searching for a good clean standard bore 427 for my Camaro. Plan is an L88 spec build. So 4 bolt main is a must. Not sure if a marine block is for me. Rob
