Old 08-22-2023, 04:54 PM
Default 70 lt-1
Corvette engine suffix codes for LT-1.
Books all show CTU and CTR
Both designations indicate manual trans and transistor ignition as well as 370 HP.
Can't be that one was with A.I.R. and one without, as all the 70 LT-1s were built with the smog pump. All LT-1s in 1970 were manual transmission.
So, what is the difference in the two suffix codes?
There is a third one (CTV) but that is clearly the ZR1.
Old 08-22-2023, 05:32 PM
Most listings show CTR but most say it was never used w/ production and all LT1’s built included CTU.
Being both stick designations, the extra suffix may’ve originally been planned for use w/ MA6 Dual-Disc clutch which was not offered w/ LT1 or for Trans. Ignition as an option which ended up being included w/ all cars?
Old 08-22-2023, 06:06 PM
John Brown's Avatar
Just checked NCRS. It says;
A 'CTR' engine code (LT1 with T/I) has appeared in print, but records indicate it was not used, and is unverified.
John Brown
PeteLeathersac (08-22-2023)
Old 08-22-2023, 07:14 PM
Makes sense.
Old 08-23-2023, 02:14 AM
LT1vette LT1vette is offline
One has power steering, one doesn't. I think it changed the size of the oil pan. Maybe a NCRS guy can jump in...
Old 08-23-2023, 02:29 AM
Post 10 makes sense.
Ignore post #2.
https://www.corvetteforum.com/forums...on-70-lt1.html
Old 08-23-2023, 02:38 AM
I was pretty sure, I had an LT1 for 27 years. But my memory on some of the details has been "faded" LOL
Old 08-23-2023, 12:43 PM
turbojet427 turbojet427 is offline
My 70 has CTK. June 70 build date, TI, no PS or PB.
The Following User Says Thank You to turbojet427 For This Useful Post:
PeteLeathersac (08-26-2023)
