The letter code will indicate assembly plant. Those with an 'G' code were Detroit Gear and Axle. E is an Eaton posi...
How can you tell if a BT 12 bolt is from a nova or camaro ?
The casting numbers were the same...and as far as I know, all the mechanical features were the same. Pretty sure they are interchangeable.
The Following User Says Thank You to WILMASBOYL78 For This Useful Post: | ||
Mike L78 (12-07-2023) |
My understanding as well, both 67-69 Camaro and 68-72 Nova are interchangeable measurement wise. I am not sure on the codes. Bill
The Following User Says Thank You to Big Block Bill For This Useful Post: | ||
![]() Quote:
-wilma
Big Block Bill (12-07-2023) |
There would be no way to tell which car it came in originally without history.
The Following User Says Thank You to Lynn For This Useful Post: | ||
Thread Tools | |
Display Modes | |
