Old 01-23-2024, 04:29 PM
1967 4K's Avatar
1967 4K 1967 4K is online now
Talk to BTR , Brian Tooley Racing in Bardstown, Ky.. I put one of their camshafts in a 5.3 LS engine and so far no issues. Pretty sure they are grinding their own camshafts. Not sure if they’re into BB Chevy stuff.
Richard
1967 Camaro SS 396/375 4K
Old 01-23-2024, 05:14 PM
Big Block Bill Big Block Bill is online now
Like Rick said: "The solid lifter sound is what makes the LS6 Chevelle stand out. Quieting that cam ruins it for me. Like taking the whine out of an M22 or the sound of a Rolls Royce Merlin. Silence it and it’s just another engine."
My last NOS LS-7 crate engine ate a NOS solid LS-6 camshaft due to excessive valve spring pressure on the new GM Aluminum heads I used on it. I then installed a Comp Cams hydraulic roller, and it never was the same, performance nor sound. Bill
The Following User Says Thank You to Big Block Bill For This Useful Post:
427 (01-24-2024)
  #13
Old 01-23-2024, 05:26 PM
Originally Posted by Lynn View Post
Interesting discussion from 2013. Don't know how one would verify everything stated.
Camshaft Machine Company (CMC) located in Jackson, Michigan was established in 1942 and is probably the largest designer and manufacturer of automotive camshafts in the world. CMC produces cams for GM, Ford, Chrysler, Comp Cams, Lunati, Edlebrock, Crane, Wolverine and many others.
Most (but not all) of the automotive camshafts produced today are produced at one of the Big Three cam manufacturers all located in Michigan. CMC of Jackson, MI., Engine Power Components (EPC) of Muskegon, MI., and Waver Bartel Cam Company, of Grand Haven, MI.
CMC purchased Wolverine approximately 1990/1991.
Crane Cams purchased CMC around 1995 and Wolverine was included in this purchase. During this period Crane owned both Wolverine and CMC.
Crane sold CMC to Federal Mogul about April or May of 1999. Crane did not sell Wolverine to Federal Mogul and Crane still owns Wolverine. Federal Mogul also owns the Waver Martel Cam Company.
CMC was the OEM supplier for most of the muscle car cams for GM, Ford, Chrysler and others back in the muscle car era. This included the infamous 9779067, 9779068, 9779041 etc. CMC currently supplies many cams to the OEM manufacturers and holds copyrights for many OEM grinds. If you purchase a Pontiac original muscle car grind like the 068 for an example, no matter whom you purchase it from it will be made by CMC.
Another interesting tid bit is that some time prior to 1990 when Crane and Wolverine were competitors Crane developed their own version of the Pontiac 9779068 (and maybe others) but advertised it as a computer enhanced version and not an exact duplicate. The reason that Crane did not produce an exact duplicate is because CMC still holds copyrights to this cam and many others.
Wolverine does not have their own cam grinding shop. CMC supplies most of the grinds to Wolverine. Crane also grinds some of Wolverine cams.
Even though Crane has their own cam grinding shop CMC still grinds some of the cams sold under the Crane name. Crane currently has the contract for the Summit brand cams. Crane also grinds some cams sold under the Wolverine name. Those Summit cams could be produced by CMC or Crane, hence the rumored Wolverine Summit connection.
It has been rumored that Crane makes all Wolverine Cams and this is not true. Most of the cams sold under the Wolverine name are produced by CMC. It is true that a small percentage of cams sold under the Wolverine name are produced at the Crane manufacturing facility. To complicate things further it seems that certain grinds could be purchased under the Crane or Wolverine name that are the exact same grind, and CMC or Crane depending on the grind could have produced the cam.
It’s interesting that most people have not heard of CMC, EPC, or Waver Bartel even though they have been around for a very long time, longer than a lot of us have.
Not much will change now that Federal Mogul owns CMC. They will still produce the same cams and will pretty much supply them to the same customers sold under various nameplates. Federal Mogul recently acquired the TRW automotive products division also. The infamous TRW forged pistons that are so popular with we Pontiac folks are still produced at the same factory as when they were owned by TRW. Federal mogul also now owns seal Power. Federal Mogul also purchased the Clevite Bearing company. This gave Federal Mogul an almost airtight grip on the automotive bearing industry. This created an unfair marketing advantage and the Federal trade Commission (FTC) required Federal Mogul to sell Clevite, which they have done.
So the next time you buy your new Comp Cams, Lunati, Ultradyne, Iskenderian, Engle, or other cam there is a good chance it was actually made in Michigan at one of the top three cam makers. What the cam companies do is have their proprietary grinds (design, lob profile etc.) and have them ground by one of the big three. Very few cams are actually ground by a name brand cam company, Crane is one exception but they don’t grind all of theirs either.
Is Crane still in business? Seems like I heard Comp bought them out. I know their restoration blueprint cam business is gone. i bought a LT-1 cam https://www.summitracing.com/parts/crn-110951/overview
in 2016 and it has the CMC logo and "Proferall" cast into it. Said it was Made in the USA. Hopefully it is the good stuff.
Owned since 1978 - First Car
Old 01-23-2024, 07:48 PM
dustinm dustinm is offline
How many miles are on the original cam/lifters? I would most likely reuse what you have.
If you had to send out the current lifters for a recrown/polish.
Old 01-23-2024, 08:09 PM
I've had a high frequency hearing loss since infancy, so I have never, truly, heard a solid lifter camed engine. I could hear certain levels of ticking when I was younger, but that deteriorated over time and they all sound alike to me now anyway...
Old 01-23-2024, 11:45 PM
1971ls6's Avatar
1971ls6 1971ls6 is offline
Look at a Crower solid roller,they use a large lash that sounds like the old school solids.
The cost is not that much more, and dam near 100* you will not have to remove it on the same weekend you fire it up.
The Following 3 Users Say Thank You to 1971ls6 For This Useful Post:
69 Post Sedan (01-24-2024), dykstra (01-24-2024), Xplantdad (01-24-2024)
  #17
Old 01-24-2024, 11:15 AM
69 Post Sedan's Avatar
I’m also a big fan of the clattering of a solid lifter car., I’d do anything I could to run at least a solid roller as it’s the easiest to do the initial startup but if you can find a good solid flat tappet solid lifter supplier, I’d try that route.
I spoke to one engine builder and he ONLY uses USA made Johnson Lifters for his builds…..but it looks like they only make roller lifters. So if you decide to go with a solid roller, maybe check them out.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-24-2024, 11:46 AM
Richls5's Avatar
Richls5 Richls5 is offline
Originally Posted by big gear head View Post
I just love a good flat tappet solid. Be careful with a solid roller on the street. Some of them don't do well. I had one in my car for a few years and I got tired of replacing distributor gears and the rollers in the lifters were going bad.
Just remember, it's YOUR decision. Don't let someone talk you into something that you don't really want.
yeah im aware ive just been using this family to build motors for over 20 years and hes never steered me wrong. this is the first stock motor hes done everything has always been improved over stock
Old 01-24-2024, 03:05 PM
Crossbreed383 Crossbreed383 is offline
I responded to a thread here not long ago explaining the issues with most cam failures these days but no one seemed responsive ??
Oh and I work at BTR and do all the custom cam work as well as run the Spintron and engine dyno from time to time when help is needed .
We are grinding cams inhouse but aren't doing anything BB although I spec and have them ground for customers all the time
Nick E.
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
The Following 7 Users Say Thank You to Crossbreed383 For This Useful Post:
427 (01-24-2024), big gear head (01-24-2024), dustinm (01-24-2024), Igosplut (01-26-2024), PeteLeathersac (01-24-2024), Pro Stock John (01-24-2024), Xplantdad (01-24-2024)
  #20
Old 01-24-2024, 05:00 PM
Nick E.
Here’s the thread from 10/23 w/ comments as Pg.#2 Post 14 and on…
https://www.yenko.net/forum/showthread.php?t=177064
RobR (01-24-2024)
