#11
Talk to BTR , Brian Tooley Racing in Bardstown, Ky.. I put one of their camshafts in a 5.3 LS engine and so far no issues. Pretty sure they are grinding their own camshafts. Not sure if they’re into BB Chevy stuff.
Richard 1967 Camaro SS 396/375 4K 2002 Camaro 35 Anniversay Z4C-WU8 |
#12
Like Rick said: "The solid lifter sound is what makes the LS6 Chevelle stand out. Quieting that cam ruins it for me. Like taking the whine out of an M22 or the sound of a Rolls Royce Merlin. Silence it and it’s just another engine."
My last NOS LS-7 crate engine ate a NOS solid LS-6 camshaft due to excessive valve spring pressure on the new GM Aluminum heads I used on it. I then installed a Comp Cams hydraulic roller, and it never was the same, performance nor sound. Bill Last edited by Big Block Bill; 01-23-2024 at 05:25 PM. |
The Following User Says Thank You to Big Block Bill For This Useful Post: | ||
427 (01-24-2024) |
#13
![]() Quote:
in 2016 and it has the CMC logo and "Proferall" cast into it. Said it was Made in the USA. Hopefully it is the good stuff.
70Z28 04B Norwood Forest Green-white Stripes Black DeLuxe Interior Owned since 1978 - First Car Last edited by BCreekDave; 01-24-2024 at 02:44 PM. |
#14
How many miles are on the original cam/lifters? I would most likely reuse what you have.
If you had to send out the current lifters for a recrown/polish. |
#15
I've had a high frequency hearing loss since infancy, so I have never, truly, heard a solid lifter camed engine. I could hear certain levels of ticking when I was younger, but that deteriorated over time and they all sound alike to me now anyway...
#16
Look at a Crower solid roller,they use a large lash that sounds like the old school solids.
The cost is not that much more, and dam near 100* you will not have to remove it on the same weekend you fire it up.
1969 ZL1 COPO Camaro 11.60@120 F.A.S.T 21 1971 LS6 vette 12.20 @118 PSMCDR |
The Following 3 Users Say Thank You to 1971ls6 For This Useful Post: | ||
#17
I’m also a big fan of the clattering of a solid lifter car., I’d do anything I could to run at least a solid roller as it’s the easiest to do the initial startup but if you can find a good solid flat tappet solid lifter supplier, I’d try that route.
I spoke to one engine builder and he ONLY uses USA made Johnson Lifters for his builds…..but it looks like they only make roller lifters. So if you decide to go with a solid roller, maybe check them out. Kurt
![]() 1969 SS396 Post Sedan Delivered to Van-T Topeka KS MCACN Day2 Concourse Gold Award 1965 VW El Lobo Dune Buggy built in the mid 70’s for the Iowa Shriners 1968 Schwinn Orange Krate 1969 Schwinn Pea Picker 1968 Schwinn 5-Speed 1970 Schwinn 3-Speed Deluxe 1972 Schwinn 10-Speed Continental 1973 Schwinn 5-Speed Suburban All Original Paint Bikes |
#18
![]() Quote:
#19
I responded to a thread here not long ago explaining the issues with most cam failures these days but no one seemed responsive ??
Oh and I work at BTR and do all the custom cam work as well as run the Spintron and engine dyno from time to time when help is needed . We are grinding cams inhouse but aren't doing anything BB although I spec and have them ground for customers all the time Nick E.
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D 84 Mustang/Hertz Rent-a-Car 438CI 5.58@123 8.80@147 On Radials ALL MOTOR Powered by my 13 year olds engine program 68 NOVA 396-375 HP F.A.S.T. Project |
The Following 7 Users Say Thank You to Crossbreed383 For This Useful Post: | ||
427 (01-24-2024), big gear head (01-24-2024), dustinm (01-24-2024), Igosplut (01-26-2024), PeteLeathersac (01-24-2024), Pro Stock John (01-24-2024), Xplantdad (01-24-2024) |
#20
![]() Quote:
https://www.yenko.net/forum/showthread.php?t=177064 ![]() ~ Pete .
The Following User Says Thank You to PeteLeathersac For This Useful Post: | ||
RobR (01-24-2024) |
Thread Tools | |
Display Modes | |
