Old 02-01-2024, 01:59 AM
Steve Shauger's Avatar
Administrator
Default 69 Z28 Coil springs
I want to replace the coil springs in my orange/white stripe Z I recently picked up, because it sits too high. I installed Moog 6308 in my other orange Z and for me it sits perfect. The rub is they are discontinued. From my research D&R sells pn k00091-z which is designed for a 69 Z28 and looks to match the original specs. Also available from Classic Industries are Elgin pn CS6308 which also closely matches the Moog original specs. My question is has anyone installed either and do you like the height? also if you have pics that would be great. Any other spring suggestion would be appreciated!
Thanks...
www.yenko.net
www.vintagecertification.com
69L78 (02-01-2024)
Attachments - The Supercar Registry Screenshot_20240202_164227_Gallery.jpg Screenshot_20240202_164034_Gallery.jpg IMG_8537.jpg IMG_3525.jpg
Old 02-01-2024, 10:22 PM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Steve, why don't you just trim the coils you have until you get the ride height you want?
Old 02-02-2024, 05:07 AM
cruiserofland's Avatar
cruiserofland cruiserofland is offline
Steve, I worked with Kevin at Coil Spring Specialties last year on a custom set of front coil springs. I first ordered in the spec recommended by Wayne D Guinn which brought my front fenders down to about 25 3/8”, measured from the center of the fender trim. I wanted lower to sit level with the rears so I ordered a second adjusted set that got me to 24 3/8”. I bet you can ask Kevin for the spec that Matt from California ordered last year. Or if you want 25 3/8” I’ve still got those in a box. Here are a few photos of ride height on 215/65 BFGs. DM me if you need any more details.
Thank you to Motorhead848 for refinishing and installing them
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
The Following 8 Users Say Thank You to cruiserofland For This Useful Post:
enio45 (02-03-2024), Jonesy (02-02-2024), L72Chevelle (02-03-2024), napa68 (02-03-2024), olredalert (02-02-2024), rlw68 (02-02-2024), ruralrte66 (02-04-2024), Zman1969 (02-02-2024)
Old 02-02-2024, 04:07 PM
Administrator
The car stance is perfect! I used them in the mid 90's on a 69 Pacecar big block auto with A/C. I tried 3 sets from Eaton springs with horrible results. I then contacted Coil Spring Specialties and first set were perfect.
I was contacted from a member and just purchased a set of unused 6308.. BTW our cars are twins!!
I have 215/65/15 front and 235/60/15 rear. They have almost identical diameters...
Thanks for reaching out!
www.yenko.net
The Following 2 Users Say Thank You to Steve Shauger For This Useful Post:
cruiserofland (02-02-2024), napa68 (02-03-2024)
Old 02-02-2024, 06:57 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Really good info here. Thanks
The Following User Says Thank You to Jonesy For This Useful Post:
Old 02-02-2024, 10:11 PM
Motorhead848 Motorhead848 is online now
matt,
has the car settled at all since we did the second set?
-mark
Old 02-03-2024, 02:05 AM
enio45 enio45 is offline
what is the recommended ride height - using stock spring and stock bias tires?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-03-2024, 08:01 PM
Originally Posted by Motorhead848 View Post
matt,
-mark
Mark, so far I’d say it’s within 1/8” of the day you installed them, though I’ve (sadly) put maybe less than 100 miles on the car since the install. I’m expecting a bit more settling than that so we’ll see after I replace the dead fuel pump.
Eddie, here’s the page in the AIM about ride height. I’ll have to measure from those locations and compare, but certainly the look I prefer is level and with the tires slightly tucked into the fenders. I like to think GM Styling would agree
I should also say that my springs from Coil Spring Specialties are 507 lbs/in, which is stiffer than stock. The front feels very planted in cornering without a compromise in ride quality
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
The Following 3 Users Say Thank You to cruiserofland For This Useful Post:
L_e_e (02-04-2024), olredalert (02-04-2024), Zman1969 (02-07-2024)
