Old 02-26-2024, 02:22 AM
scuncio scuncio is offline
Originally Posted by OneStopRestoration View Post
I only had one orignal brake drum, but cleaned it up and bored it out. I see they now sell some non finned new replacement drums. I may have to just get one.
I’ve thought about doing this on a Bridgeport. What tool did you use, and how did it turn out?
Ryan1969Chevelle (02-26-2024)
  #112
Old 02-26-2024, 02:53 AM
OneStopRestoration OneStopRestoration is offline
Just a standard boring bar with 5/8" bar and carbide insert. I think they turn out nice but sometimes you do get some chatter. I had to really slow down the spindle speed to almost the min the machine would run to make it all work.
Old 02-26-2024, 02:58 AM
Thanks! I’ll be trying this soon.
Old 02-26-2024, 11:02 PM
mrays mrays is offline
Originally Posted by mprice View Post
The yellow Yenko Chevelle that Legendary had was one of my old cars. I purchased it from Vince and after I sold it the next owner he then located the original motor, rear and trans. When I told Vince he found them he responded with yea I knew they were there but the motor was 60 over so I didn't tell you about it. I thought oh shit. I found the Yellow Yenko John now has in North Carolina and when advertised it was a complete car. It was in Hemmings sometime in the early 80s after which Carl Dwiggens acquired it, then Dick Bridges then Randy Miller to me and finally John purchased the car and did his usual outstanding restoration on it.
So are there three known Butternut Yellow Yenko Chevelles with black vinyl tops and TH400 transmissions? The car that Legendary had was sold out of Nankivell in Indianapolis and the car that Ron Norman had was sold out of Muscatel in Fargo ND. This was discussed before but I can't find it on here now.
Old 02-27-2024, 12:32 AM
Page 3 of this 03/15 thread includes some info on these cars…
https://www.yenko.net/forum/showthread.php?p=1254486
Old 03-05-2024, 11:41 AM
chevyman0429's Avatar
What type of product are you using for your blasting and what are you prepping the blasted surface with before painting ? Thanks
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 03-06-2024, 12:47 AM
Default Frame Blasting and First Prime
I use basic sand blasting sand and a standup outdoor blaster. For many of you following I dont get bogged down in the details of thinking the most exocitc process is the best. I keep things as simple as I can. In terms of sand I use the stuff stocked at the local Menards for those that live in the midwest. Most here on the forum are gonna die laughing but I still use the old school lacquer based primers. Im not afraid to use the lacqur direclty on the blasted metal. Once I get into the stage of sanding and removing pits 90% of the first coat is sanded off. Body panel work is a total different story. I get into the more better adhering epoxy primers for my basecoat but still layer body filler and lacquire primer on top of that.
Ocassionally i will use a 2k high build primer but I will only get into that with easily sanded surfaces and heavier pitting. This car will not require and 2k as im already finding a single sand is elimating all pits if they even exist.
The Following 10 Users Say Thank You to OneStopRestoration For This Useful Post:
67 Nova Boy (04-11-2024), big gear head (03-06-2024), chevyman0429 (03-06-2024), dykstra (03-06-2024), mhurd (03-06-2024), olredalert (03-06-2024), ragtop (03-06-2024), RPOLS3 (03-06-2024), Tenney (03-06-2024), Zman1969 (03-07-2024)
  #118
Old 03-07-2024, 12:18 PM
Zman1969 Zman1969 is offline
that is a thankless job right there!
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
The Following User Says Thank You to Zman1969 For This Useful Post:
  #119
Old 03-07-2024, 12:49 PM
AND takes all day with a pot blaster. I see you sweep it up and screen it back in the pot too. Been there, done that, but only once. Now I farm that out. Getting more difficult to find places that blast anymore though.
Your media looks like black diamond, coal slag. I do use that on frames but use the white play sand for other things.
Old 03-11-2024, 08:54 PM
Default 12 Bolt 4 Series Carrier for the 4.56
Well Scratch my earlier question on this. Just as an update. I decided it would compliment the L89 to go with a set of 4.56 grears when i get to assembling the rear end. Managed to find a real nice guy on facebook that sent me a carrier that had some damage in the pinion shaft area. Sent me a second housing.
Its nice to see some folks out there have some high levels of integrety in spite of what you see in the news or online.
67 Nova Boy (04-11-2024), big gear head (03-12-2024), Dave Rifkin (03-12-2024), dykstra (03-12-2024), Jims69z28 (06-13-2024), olredalert (03-12-2024), PeteLeathersac (03-12-2024), Ryan1969Chevelle (03-12-2024), Tenney (03-12-2024), Zman1969 (03-20-2024)
