Old 03-12-2024, 02:02 PM
ALLZS ALLZS is online now
Default 1967 camaro rs battery draw
what can cause the battery to drain down overnight on a 67 rs camaro convertible there are no interior lights left on or other aux lighting
Old 03-12-2024, 03:59 PM
danachevroletfor1967 danachevroletfor1967 is offline
Do you have an underhood light? My '67 Camaro would drain the battery when the mercury switch, or whatever controlled the light, stopped working and the light would stay on with the hood closed. The only way I discovered this much later was noticing a light pattern on the garage floor after closing the hood.
Old 03-12-2024, 04:07 PM
Big Block Bill Big Block Bill is online now
Start by removing the negative battery cable and installing a 12 volt test light between the negative post on the battery and the cable end. With everything off, and the doors closed, If the test light lights up, you have a draw in the battery. Next remove (1) fuse at a time until the light goes out to see which circuit the draw is in. If you pull all the fuses and the test light is still lit, disconnect the positive wire to the alternator. If the test light is still lit, disconnect the positive cable to the starter. If the light is still lit, you have something positive shorting to ground. Bill
The Following 5 Users Say Thank You to Big Block Bill For This Useful Post:
juliosz (03-17-2024), Kurt S (03-13-2024), L_e_e (03-12-2024), olredalert (03-14-2024), Too Many Projects (03-12-2024)
Old 03-12-2024, 10:05 PM
Bill is right on, but if you are still running the original style, externally regulated alternator, I would start there before pulling fuses. My experience with this when these cars were still around is that a diode would short out in the alt and ground out. You can look at the dash in the dark and see if the alt light is faintly glowing too. I've seen that happen with a shorted alternator.
If the alt isn't the issue, then start pulling fuses...
Old 03-12-2024, 10:20 PM
thehornworks thehornworks is offline
Don't discount a bad battery. They are not good or long lasting now a days
Old 03-13-2024, 07:02 PM
Kurt S Kurt S is offline
Some solid advice!
Kurt S - CRG
Old 03-13-2024, 07:40 PM
going to work on this over the weekend thanks for all the in put will let you know what i find
Old 03-13-2024, 08:27 PM
169indy's Avatar
169indy 169indy is offline
Don't forget disconnecting the Voltage Regulator also as part of you isolation methods.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 03-16-2024, 12:39 PM
well it looks like i found the problem the brand new voltage regulator is junk
The Following 6 Users Say Thank You to ALLZS For This Useful Post:
1967 4K (03-16-2024), danachevroletfor1967 (03-16-2024), dykstra (03-17-2024), napa68 (03-16-2024), ragtop (03-18-2024), Too Many Projects (03-17-2024)
Old 03-17-2024, 01:18 AM
Not the first time we have heard this about them. Glad you found the issue and can now correct it.
