1967 camaro rs battery draw
what can cause the battery to drain down overnight on a 67 rs camaro convertible there are no interior lights left on or other aux lighting
Do you have an underhood light? My '67 Camaro would drain the battery when the mercury switch, or whatever controlled the light, stopped working and the light would stay on with the hood closed. The only way I discovered this much later was noticing a light pattern on the garage floor after closing the hood.
Start by removing the negative battery cable and installing a 12 volt test light between the negative post on the battery and the cable end. With everything off, and the doors closed, If the test light lights up, you have a draw in the battery. Next remove (1) fuse at a time until the light goes out to see which circuit the draw is in. If you pull all the fuses and the test light is still lit, disconnect the positive wire to the alternator. If the test light is still lit, disconnect the positive cable to the starter. If the light is still lit, you have something positive shorting to ground. Bill
The Following 5 Users Say Thank You to Big Block Bill For This Useful Post: | ||
juliosz (03-17-2024), Kurt S (03-13-2024), L_e_e (03-12-2024), olredalert (03-14-2024), Too Many Projects (03-12-2024) |
Bill is right on, but if you are still running the original style, externally regulated alternator, I would start there before pulling fuses. My experience with this when these cars were still around is that a diode would short out in the alt and ground out. You can look at the dash in the dark and see if the alt light is faintly glowing too. I've seen that happen with a shorted alternator.
If the alt isn't the issue, then start pulling fuses...
Don't discount a bad battery. They are not good or long lasting now a days
going to work on this over the weekend thanks for all the in put will let you know what i find
Don't forget disconnecting the Voltage Regulator also as part of you isolation methods.
69 Los Z11 68 SS/RS 396/325 68 Los Z28 |
well it looks like i found the problem the brand new voltage regulator is junk
The Following 6 Users Say Thank You to ALLZS For This Useful Post: | ||
1967 4K (03-16-2024), danachevroletfor1967 (03-16-2024), dykstra (03-17-2024), napa68 (03-16-2024), ragtop (03-18-2024), Too Many Projects (03-17-2024) |
Not the first time we have heard this about them. Glad you found the issue and can now correct it.
Thread Tools | |
Display Modes | |
