Old 04-29-2024, 12:48 PM
ALLZS ALLZS is offline
Default 3927186 heads
can the small valve 186 castings be converted to the large valve
Old 04-29-2024, 12:56 PM
Steve Shauger's Avatar
Administrator
Absolutely commonly done.
www.yenko.net
www.vintagecertification.com
Old 04-29-2024, 01:15 PM
Don't forget to unshroud the intake valve area in the combustion chamber, otherwise just stay with the 1.94's as they will flow better without the cut.
Owned since 1978 - First Car
Old 04-29-2024, 02:07 PM
Try to find pictures of the original Z28 LT1 heads and copy them. It's more than just putting in larger valves. The combustion chambers also need to be modified.
Old 04-29-2024, 05:01 PM
Will it run any better or worse with the small valve heads on a lt1 350
Old 04-29-2024, 07:37 PM
dustinm dustinm is offline
I doubt you will be able to feel any difference
Old 04-29-2024, 09:32 PM
If you are running exhaust manifolds and full exhaust, don't bother.
