Old 05-01-2024, 02:10 PM
Yes, long home made bars. When you say flip the rear end I hope you mean moving the spring perches from the bottom of the axle tube to the top and not actually turning the rear end over. You also need to make the rear end float in the spring perch. If the bars have a different arc than the springs then your suspension will bind.
