Old 06-18-2024, 02:26 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Default 1969 Z/28 crank pulley 3956668 - used & cheap
Hi Gang, I have a used 3956668 CG SBC HiPo deep groove crank pulley available.
It's certainly original, and is cheaper, because it's been "modified" by a previous owner, and I'm not sure why...
Anyway, the rear register has been shaved off and the center crank bolt hole has been enlarged; see the photos.
I'm sure it will still function, and certainly appear as intended / original for what it's worth. The three pulley bolts will attach as intended and center the pulley and maybe a larger crank bolt washer if needed...
In any event, it is what it is and a cheaper way into a real GM, assembly line pulley - there's a very slight ding in one of the grooves I've shown that could certainly be tapped out I'm sure.
160.00 PPFF shipped to the 48
Cheers all,
Anthony
Attachments - The Supercar Registry IMG_2753.jpg IMG_2752.jpg IMG_2751.jpg IMG_2750.jpg
Old 07-22-2024, 05:28 AM
AnthonyS's Avatar
60.00 shipped now. Would like someone to give it a chance.
Cheers all,
Anthony
