Old 05-01-2024, 12:42 PM
LetsFNgo's Avatar
LetsFNgo LetsFNgo is online now
Default Street freak rear suspension
So I was born far too late to know, but for a gasser/street freak in the very late 60’s and early 70’s, what type of traction device would’ve been used on a lead spring suspended rear axle?
For what I’m building and to fit N50’s hanging out the side I’m going to flip the rear so it’s spring over axle. Would some type of ladder bar have been standard fair back then on something like that?
I’d like the car to sit something like this Falcon when done. Even though im building a Rambler.
Thank you.
AMC weirdo
The Following 2 Users Say Thank You to LetsFNgo For This Useful Post:
67 Nova Boy (05-03-2024), markinnaples (05-02-2024)
Attachments - The Supercar Registry IMG_5520.jpg IMG_4249.jpeg IMG_4196.jpeg IMG_4195.jpeg
Old 05-01-2024, 12:57 PM
Ladder Bars, long ladder bars, 3' to 4' long. Traction bars don't work once you flip the springs to the top. Most of them were home made.
The Following User Says Thank You to chevyandpontiac For This Useful Post:
LetsFNgo (05-01-2024)
Old 05-01-2024, 02:10 PM
Yes, long home made bars. When you say flip the rear end I hope you mean moving the spring perches from the bottom of the axle tube to the top and not actually turning the rear end over. You also need to make the rear end float in the spring perch. If the bars have a different arc than the springs then your suspension will bind.
Old 05-01-2024, 02:28 PM
LetsFNgo's Avatar
Yes. Meaning going from spring under rear to spring over moving the perches. I don’t need 4 speeds in reverse.
AMC weirdo
Old 05-01-2024, 08:15 PM
Exactly. I know someone who did that and was very surprised the first time they tried to drive it.
Old 05-01-2024, 09:15 PM
useless tony useless tony is offline
Reminds me of the time my nephew got the steering cables reversed on his outboard. Turn the wheel left, the boat swung right.
Old 05-02-2024, 01:26 AM
Lynn Lynn is online now
You ought to try reversing the power steering hoses going to the control valve on a C3 or C4 Corvette. Start it up and the wheel turns violently from side to side until you shut the car off!!!!
Old 05-02-2024, 10:23 PM
LetsFNgo's Avatar
It’s all coming together. Narrowed truck Dana 60 swapped in with the perches up top.
AMC weirdo
The Following 5 Users Say Thank You to LetsFNgo For This Useful Post:
67 Nova Boy (05-03-2024), big gear head (05-03-2024), dykstra (05-04-2024), markinnaples (05-08-2024), Pro Stock John (05-03-2024)
Old 05-29-2024, 08:07 PM
LetsFNgo's Avatar
Not sure if I should start a build thread in the AMC section for this. But here’s where it currently sits. Ended up removing 3 leafs from each side as the leafs speedway provided were way too heavy. The rear is sitting spring under. With 5.13 gears and a spool.
Built the rear with my dad on Memorial Day. Measured for the steering linkage. Pretty soon it’ll be moved into the garage so the bodywork and other repairs can start. I also need to figure out the Ladder bars for it.
AMC weirdo
The Following 6 Users Say Thank You to LetsFNgo For This Useful Post:
69 Post Sedan (07-05-2024), chevyandpontiac (05-30-2024), dykstra (05-29-2024), L78_Nova (05-29-2024), markinnaples (05-30-2024), scuncio (07-03-2024)
Old 06-30-2024, 08:26 PM
LetsFNgo's Avatar
GM A body Lakewood ladder bars and N50’s on 15x10 slot mags look good. I think it’ll fit the era I’m going for. Now I wish I could find a used GMC 671 blower to rebuild.
AMC weirdo
The Following 3 Users Say Thank You to LetsFNgo For This Useful Post:
cheveslakr (07-03-2024), dykstra (07-01-2024), markinnaples (06-30-2024)
