Old 07-08-2024, 01:20 AM
Coolant recovery tank mounted.
dykstra (07-08-2024)
  #22
Old 07-08-2024, 01:27 AM
The framework for the dash panel has brackets welded on both sides. I think that makes a great place to mount a throttle control.
Haven't had a lot of time to spend on this, but pleased with the progress.
Planning on a 90 degree brass elbow in the radiator drain attached to a ball valve, with a hose attached for draining the coolant. I hate slow messy petcocks. Also plan to run the top overflow hose from the recovery tank to a secondary catch can, just to make certain I don't have any coolant spills.
dykstra (07-08-2024), olredalert (07-08-2024)
  #23
Old 07-08-2024, 10:59 AM
dykstra's Avatar
dykstra dykstra is online now
That engine test stand is turning out pretty slick!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
Old 07-08-2024, 02:46 PM
It is ugly as sin; but I don't think the ugliness will affect performance.
Old 08-03-2024, 02:13 PM
Looking at throttle control cables. I can really go overboard on this (as far as using salvage or scrap parts) and use the old knob and bowden cable assembly that I took off my 49 Studebaker dump truck when I converted the hydraulic dump control from PTO to an electric over hydraulic set up.
But for this I think I want a new part; something with a handle and lever so I can control throttle opening more precisely.
Can't find much other than lawn mower, marine and heavy equipment controllers.
Old 08-12-2024, 02:15 AM
Decided to just use the old PTO cable and handle from my Studebaker. It is 75 years old and way over built. Very thick cable. Moves freely, and I can cut it to size once I have everything dialed in. I can get about 4 inches of travel out of it, but shouldn't need that much.
Old 08-12-2024, 02:17 AM
Added an overflow system for the coolant. I already have a coolant recovery tank, but just in case THAT system overflows (I hate getting coolant on the floor) I ran a tube to an old antifreeze jug that sits snugly down in the channel iron.
dykstra (08-12-2024), olredalert (08-12-2024)
  #28
Old 08-12-2024, 02:21 AM
Got the cutouts done for gauges and control panel. Control panel has a master switch and three accessory switches.
Also has a built in push button for the starter.
Have an extra gauge hole. I bought a dual Air Fuel Ratio set up thinking that it included two gauges. Well, it does, but BOTH gauges (left and right) are contained in a single pod.
I have a volt gauge on the way, and may mount a fuel pressure gauge.
If anyone wants a vintage RAC (made in Japan circa 1971) Amp gauge, it is yours for free.
I have no use for it.
  #29
Old 08-12-2024, 02:24 AM
Also mounted a low pressure fuel pump for carb applications that will be using electric pumps. It will go on circuit 3. I started to mount it on the outside, but figured it would be safer on the inside. It is right next to the fuel tank. Just need a couple of 90 degree elbows to get fuel to it.
  #30
Old 08-12-2024, 02:30 AM
Forgot to mention that I made a mount for the battery. Welded in two pieces of angle iron. You can see the burn through, so I know I got good penetration.
Laid a piece of 3/8 plywood on the angle iron, then put the battery on top.
Keeping with the budget build, I just used a left over ratchet strap for a hold down.
As you can see, I also removed my original 69 Z/28 engine block as the test fitter. I felt disrespectful.
Once I get all the gauges, then I need to wire it up. Not looking forward to that.
The fan set up came with a temp sensor. Planning to put that in line on the lower hose. Also included a bunch of connectors and a relay. However, it did not include any instructions. Hopefully, it isn't too difficult to figure out. Never put an electric fan on an old car before.
