Interested to learn who has added E-Track and using Over the Tire Strapping
inside your enclosed trailer...............and is it acceptable to BOLT on top of Wood Floor with Fender Washers and Nyock nuts on Underside??????
Chuck Sharin [email protected] Auburn,WA (30 miles South of Seattle) 70 Camaro R/S Z-28, L-78, R/S SS 69 Camaro COPO "recreation" |
Just did this on my 24 Ft Trailer. Used E track and made to measure straps from Macs Tiedowns. Used Grade 8 bolts and large washers with nylon nuts underneath. Tracks were placed for 59 inch front and rear track and minimum 108 inch wheelbase.
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, completed 68 Camaro Z28,Corvette Bronze,Houndstooth 2016 Porsche Carerra Cab and 2021 C63S AMG ,modern fun. www.vancouverclassiccars.com |
They make backing plates for the e track. I would not think bolts with washers would be safe through plywood alone. Backing plates and bolting through crossmembers would be best.
The Following 4 Users Say Thank You to all_about_cars For This Useful Post: | ||
I would want backing plates also and nylock nuts WILL work loose. After I had a couple nylock nuts work loose from vibration on a trailer, I now only use all steel crimped locking nuts.
I bought a new 6x10 enclosed trailer to haul my Harley and had to place the rings in the floor and cut backing plates for them ..LOL The Harley and trolley might weigh 1,000 lbs, but under severe braking or a collision, it isn't going to rip loose from the floor.
I used e-track in my Harley trailer and made 4"X4" backing plates cut from flat bar fore and aft of the the wheels. I'm kicking around the idea to purchase another trailer and will go the same route.
Good Judgement comes from Experience. Some Experience comes from Bad Judgement" Albert Einstein Last edited by 396 SS/RS; 07-10-2024 at 03:00 AM. |
I always add e-track to my enclosed trailers. The flexibility for moving tie down points is great - especially when hauling ATVs. However, for bigger cars it’s kind of a PITA to fit yourself between the wall of the trailer & the car to install the anchors. Anybody else find that to be an issue?
I don't trust that single strap setup but I am usually hauling drag cars with skinny front runner tires. I just had a buddy hauling a car on a dolly that had a single strap come off on one side. I have straps that form a basket that go on each side of the tire with a strap over the top of the tire to tie it together. It is adjustable for tire size. Never have had it come loose.
I ordered 4 x 5 foot pieces of Horz E Track from TruckingDepot.com as their shipped
priced was better than Harbor Freight and others........... I bought one extra 5' Piece that I am going to cut into shorter pieces and use for backing plates under the wood floor of my Pace American Trailer Now I will order 4 x https://www.autohaulersupply.com/cat...het-553839.php from AutoHaulerSupply.com and 4 x https://www.autohaulersupply.com/cat...-dw-554785.php so I can use my own ratchets (I have many extra)
The Following User Says Thank You to CamarosRus For This Useful Post: | ||
R68GTO (08-27-2024) |
I have e-trac in my 24 footer. Screws through plywood seem to hold just fine, just use enough of them. Some go thru the trailer crossmembers. I also installed the moveable e-trac wheel chocks in the front. It helps for consistent tongue weight and will take the bulk of the force in a hard brake event which will be your highest load on the e-trac
SOLD 1969 427 COPO Camaro Lemans Blue/Black, M22 4 speed, 15,800 original miles |
The Following User Says Thank You to R68GTO For This Useful Post: | ||
Pro Stock John (08-27-2024) |
I had my trailer custom made with the E track and I use over the tires straps and they have worked flawlessly for 6 years now
Frank Szymkowski 1987 Mustang GT convertible, scarlet red/titanium, white top and white/red leather, 5 speed, 3.08, factory EQ 1969 GTO Judge Warwick blue/blue, RAIII, 4 speed, tach/gauges, safe t track, flip headlights, 3.55's, ps and radio. |
The Following User Says Thank You to flyingn For This Useful Post: | ||
Blown32 (09-03-2024) |
Thread Tools | |
Display Modes | |
