Old 07-18-2024, 01:47 PM
napa68 napa68 is offline
How's the car coming along Paul?
PeteLeathersac (07-18-2024)
  #102
Old 07-18-2024, 01:55 PM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Proving Ground test cars had similar Bowtie decals.
The Following 8 Users Say Thank You to 1967Z28 For This Useful Post:
1967 4K (07-18-2024), dykstra (07-19-2024), juliosz (07-18-2024), markinnaples (07-18-2024), olredalert (07-19-2024), PeteLeathersac (07-18-2024), Tenney (07-18-2024), YenkoYS-199Stinger (08-22-2024)
  #103
Old 07-18-2024, 10:33 PM
juliosz's Avatar
juliosz juliosz is offline
It’s coming along nicely, Tim. Just finishing up on the wiring and will then dress the engine compartment. Just got a call from my stainless/chrome guy and my plating is done….need to pick it up and (ugh) pay. I’m terrible at documenting the progress and posting pics. I’ve been taking short videos and sending to the original owner.
On a separate note, I’m thankful this project came with three tubs of NOS fasteners. I didn’t realize how hard it is to find some of these like speedometer cable clips as an example.
The Following 8 Users Say Thank You to juliosz For This Useful Post:
1967 4K (07-19-2024), 1967Z28 (07-19-2024), 67since67 (07-19-2024), 69M22Z (08-14-2024), dykstra (07-19-2024), napa68 (07-19-2024), olredalert (07-19-2024), PeteLeathersac (07-18-2024)
  #104
Old 08-14-2024, 02:57 PM
juliosz's Avatar
Making progress slowly but overall pleased so far:
The Following 13 Users Say Thank You to juliosz For This Useful Post:
169indy (08-15-2024), 1967 4K (08-14-2024), 1967Z28 (08-14-2024), 69M22Z (08-14-2024), big gear head (08-14-2024), Dave Rifkin (08-14-2024), dykstra (08-14-2024), John (08-22-2024), olredalert (08-15-2024), RPOLS3 (08-14-2024), Stihl (12-13-2024), Tenney (08-15-2024), YenkoYS-199Stinger (08-22-2024)
  #105
Old 08-14-2024, 03:02 PM
juliosz's Avatar
Looking for some ideas on my fan shroud. No damage other than scratches. Has anyone had any luck with reconditioning these?
The Following 3 Users Say Thank You to juliosz For This Useful Post:
Dave Rifkin (08-14-2024), dykstra (08-14-2024), Pro Stock John (08-14-2024)
  #106
Old 08-15-2024, 04:47 PM
169indy's Avatar
169indy 169indy is online now
I would try successive fine grades of wet dry sand paper on a block to attempt to smooth the gouges however I think you can not remove enough material to eliminate them.
another option
https://www.gmpartsdirect.com/oem-pa...shroud-3893812
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 2 Users Say Thank You to 169indy For This Useful Post:
juliosz (08-15-2024), Pro Stock John (08-15-2024)
  #107
Old 08-16-2024, 06:55 PM
Kurt S Kurt S is offline
I'd try that on an old part first. I don't think you'll be able to duplicate that molded finish.
Kurt S - CRG
The Following User Says Thank You to Kurt S For This Useful Post:
juliosz (08-16-2024)
  #108
Old 08-16-2024, 07:19 PM
Thinking the same thing. I've tried to "clean up" plastic parts in the past and it never turns out well. The gouges are part of it's history and should just be left to live on with the car. If it needs to be concourse for show, find a mint used, or NOS shroud.
big gear head (08-17-2024), juliosz (08-16-2024)
  #109
Old 08-21-2024, 11:38 PM
juliosz's Avatar
Okay, sanded many of the scratches out of the fan shroud, experimented buffing with various compounds and was not fully pleased with the results. I then thought about the black trim restore stuff for exterior trim. Tried a spot on the inside of the shroud….not bad. Here’s the results (sorry for the dust/schmutz from installing).
The Following 20 Users Say Thank You to juliosz For This Useful Post:
169indy (08-22-2024), 1967 4K (08-22-2024), 1967Z28 (08-22-2024), 69M22Z (08-22-2024), Dave Rifkin (08-22-2024), dykstra (08-22-2024), gtomike1967 (08-22-2024), John (08-22-2024), L78_Nova (08-22-2024), markinnaples (08-22-2024), napa68 (08-22-2024), olredalert (08-22-2024), PeteLeathersac (08-22-2024), Pro Stock John (08-22-2024), RPOLS3 (08-22-2024), scuncio (08-21-2024), Steve Shauger (08-30-2024), SuperNovaSS (08-23-2024), Tenney (08-22-2024), TerryD (08-22-2024)
  #110
Old 08-30-2024, 07:29 PM
LITTLE TOMMIE LITTLE TOMMIE is offline
just wondering but why didn't GM put a CE replacement motor in the car instead of the DZ replacement
The Following User Says Thank You to LITTLE TOMMIE For This Useful Post:
napa68 (08-31-2024)
