Old 10-29-2024, 05:51 AM
downunder1's Avatar
downunder1 downunder1 is offline
Default Chevelle gear change.
I'm changing the gears in my Chevelle from 4:10 to 3:31.
Will the 3:31 will be okay with a 4 series carrier?
Thanks in advance,
John
Old 10-29-2024, 11:26 AM
80stang 80stang is offline
Hi,
Great choice in gears but you will need a 3 series carrier.
That's how I remember it when I last did a gear swap.
Long ago I went from those gears to 4.10s using a 3 series carrier. I could get Richmond gears with the thicker ring gear to compensate.
Good luck.
Now I want to go back again......
The Following User Says Thank You to 80stang For This Useful Post:
downunder1 (10-29-2024)
Old 10-29-2024, 11:31 AM
sixt9rsx33 sixt9rsx33 is online now
You will love the change. When I bought my 69 L78 Chevelle it had 3.31's and when I restored it I went back correct which required 4.10's. Big bummer really.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
The Following User Says Thank You to sixt9rsx33 For This Useful Post:
Old 10-29-2024, 12:39 PM
You can not put a 3.31 on a 4 series differential case. It will not work. The ring gear will be too thick and you will not be able to get it into the housing with the pinion installed.
Do you know how to set the pinion depth, bearing preload and backlash?
