Old 11-13-2024, 03:52 PM
Crossbreed383 Crossbreed383 is offline
Next up rods and pistons ............
Along with checking Rod side clearance.
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
The Following 2 Users Say Thank You to Crossbreed383 For This Useful Post:
PeteLeathersac (11-13-2024), Tenney (11-14-2024)
  #112
Old 11-13-2024, 03:55 PM
Cam installed and being degreed in to verify cam timing is correct .
Also time to check PTV( actually did this after the 1st piston was installed although I've done enough camshafts now to know this cam would fit beforehand)
Old 11-13-2024, 03:56 PM
Next up timing components along with the lifters and lifter trays ...
Old 11-13-2024, 03:59 PM
Time to add some heads . We used a Cometic .045 thick MLS gasket on this build. A OEM head gasket would have been cheaper, as these are overkill, but I wanted to set the quench at .040" since the pistons sit out of the hole .005", and there are no GM gaskets that thin.
Old 11-13-2024, 04:02 PM
Didn't get pictures of the oil pan and timing cover installation , but we just used the old stuff after some clean up of course. Time for the removal of the original 5.3 and the addition of around an extra 150 rwhp !!!
The Following User Says Thank You to Crossbreed383 For This Useful Post:
  #116
Old 11-13-2024, 04:07 PM
Cool
Engine back in a finishing up a few odd and ends ...
Added a later model L96 truck intake and 50lb flex injectors in case we wanted to go with E85 fuel down the road .
We also ended up adding a Circle D 3200 stall speed and some 1-3/4 ; headers, Y pipe w catalytic converter delete pipe . We also used on of my Borla mufflers for some added airflow and louder HOT ROD sound of course .
Doesn't look like 500+ hp now does it
Old 11-13-2024, 04:10 PM
Time for a quick base tune .
And the 1st test drive down the block....woo hoo..........
MarcDant (11-13-2024)
  #118
Old 11-13-2024, 05:10 PM
MarcDant's Avatar
MarcDant MarcDant is offline
All good looks like your boy is in tune on his project. gonna be nice little ripper, thanks for sharing.
Old 11-13-2024, 09:40 PM
dykstra's Avatar
dykstra dykstra is online now
Originally Posted by Crossbreed383 View Post
The next line of business was to clean the block and give it a quick hone along with some new cam bearings.
We could have use the Sunnen to hone the block but I wanted him to get the real hot rodders low budget experience like I did back when I was 18 and had no money ...
So a brush hone and some cylinder lube and here we go ....
The ol “dingle ball hone”.
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
L_e_e (11-14-2024)
  #120
Old 11-15-2024, 01:59 PM
So back to our regular scheduled programming ..
Will be updating progress now that I have some time .
So finally was able to get the trunk detailing done .
Added some dark base color . The pics look glossy and sort of Black in color, but it looks much flatter and more Grey when fully dried .
I had purchased some trunk splatter paint from one of the big resto shops for use in a spray gun , but it just would flow right no matter how large tip I used .
I then experimented trying to add the splatter look.
Used this old siphon style wand gun at very low psi ( 5-7 psi) we used for cleaning out heater ducting at the dealership I worked at .
Ended up spraying some epoxy paint from a spray can into a plastic cup and addingsome reducer to thin it out .
The final trick was to HEAVILY over reduce the paint so it flowed out to mimic the factory
spotting style.
Of course I figured it out as I went along so the look I was trying to achieve got better towards the end . But the finished product will work for a non concourse build and honestly back then who knows how well the cars were done from one to the other
The Following 4 Users Say Thank You to Crossbreed383 For This Useful Post:
dykstra (11-15-2024), olredalert (11-15-2024), racerkvn (11-15-2024), Tenney (11-16-2024)
