Old 08-26-2023, 05:40 PM
I have been following your thread here, and just saw your NCRS paperwork stating your car was a Framingham car. My 69 L78 Chevelle is a Framingham car too. Sold new at Monument Chevrolet Somerset Mass. My car needed a full restoration which is now 95% done and I have been working through the final details. Have fun with your build.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 09-05-2023, 02:59 PM
Zman1969 Zman1969 is offline
Originally Posted by Bill Pritchard View Post
I bought a repro sender when the one in my former 69 Chevelle convert died 7 or 8 years ago. Everything was fine except for the ground wire, which was about 6" too short to ground to the original location. Called the vendor where I bought it and asked them to measure the ground wire on others they had in stock. They were all the same length, and OF COURSE they claimed that no one else ever had a complaint about them So I sent the repro back to them and sent my original off to John Wolf & Co. in Willoughby OH. They have since rebuilt the one in my current 69 Chevelle too. Excellent workmanship and they both work as good as new.
Thanks Bill I will look them up
I got the repro too - same issue with ground wire, I did install it and seems to fixed gauge
well of course you know I filled tank last time out in it so tank was a bit of a handful
so now it reads full - not pegged full
this is like 3rd Framingham car I know of here
when I dropped tank, no build sheet but this tank was replaced at some point by original selling dealer too, I cant see date on that either
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
The Following User Says Thank You to Zman1969 For This Useful Post:
Woj (09-10-2023)
  #23
Old 09-10-2023, 03:36 PM
Woj's Avatar
Woj Woj is offline
AMK has some nice J clips that you can use for the heater box.
https://www.amkproducts.com/bulk-fas...forlookup=7710
B10256
The Following 2 Users Say Thank You to Woj For This Useful Post:
olredalert (09-11-2023), Zman1969 (09-18-2023)
  #24
Old 09-18-2023, 12:55 PM
B10256
Thanks Woj! I have couple but wasn't sure what studs got them as per your pic they are different than my Camaro.
So I took the car out yesterday while it was cooler here to do a shakedown drive and ran pretty well except for the carb - secondary's just dump and bog it down , need to play with spring and set screw, but temp was fine with a stainless flex fan, even without a shroud on it. car floats around needs upper control arm bushings as the age has taken its toll and I have another plastic weld to attempt.
90 Formula 350
The Following 4 Users Say Thank You to Zman1969 For This Useful Post:
big gear head (09-18-2023), dykstra (09-20-2023), Hawkeye (09-18-2023), L_e_e (09-18-2023)
  #25
Old 12-20-2024, 02:10 PM
time for update I had bought an assembled fresh short block from a member here and was ready to start engine assembly and decided to disassemble and have balance checked as i saw no signs of being balanced IMO crank is a 6223 and 7/16" rods had been added and in the past I had done this to a L72 warranty block I had 25-30 years ago and it needed heavy metal, this one didn't so I was at a crossroad slap it together or have it checked and not wanting to go through all this again... so apart it came, took to my machinist and when he spun it he said it was nominally heavy and needed minimum removed from crank, his thought as maybe the crank was out of a truck 366 or 427 - who knows. surprisingly crank was std std so its back together again
90 Formula 350
The Following 5 Users Say Thank You to Zman1969 For This Useful Post:
69M22Z (01-23-2025), dykstra (12-20-2024), gtomike1967 (12-20-2024), olredalert (12-20-2024), ragtop (12-20-2024)
  #26
Old 01-23-2025, 08:08 PM
daveg's Avatar
daveg daveg is offline
Rocker moldings?
Did I miss something?
Old 01-24-2025, 12:05 PM
No sir it has them several issues on this that makes me wonder it was color changed from Butternut to black a long time ago. there was a good bit of custom Chrome done my guess it was added after painting? vehicle also has one Malibu emblem on left quarter nothing on the right neither looks to have ever been changed out several have said it was a dolled up Malibu in SS clothing but the build sheet shows JD code
90 Formula 350
Old 01-24-2025, 04:44 PM
daveg's Avatar
Just curiosity.
I know 512 427-454 blocks had the clearance notch for 7/16" rod bolts.
How did you get them to clear on your block?
Nice clean car.
Congrats
Old 01-27-2025, 01:14 PM
Originally Posted by daveg View Post
Just curiosity.
Nice clean car.
Congrats
Dave this short block was built by a previous owner and I didn't notice any clearance had been done and being only a 3.76 stroke, I doubt it's needed until a 4.00" stroke is installed
90 Formula 350
Old 01-27-2025, 01:39 PM
Woj's Avatar
Woj Woj is offline
Just a quick note after rereading the thread. The driver's seat appears to be original, have you tried sending a borescope into the seat back, driver's side? You can remove the seat back release mechanism and fish the scope into the seat. I did find a left 1/3rd build sheet there in my Framingham 69 Malibu. I couldn't remove it, but was able to photograph it.
