Old 01-01-2025, 02:34 PM
Gasrat Gasrat is offline
Default 1969 Chevelle body plugs
Hello I am thinking about looking at a 1969 Chevelle convertible. Can anyone help me out with inner and outer wheelhouse as well as trunk dropoff plugs and how many of each? Are convertibles different when it comes to plugs? I’m sure they are totally different than Camaro. Pictures would be great but not necessary. Thank you. Shane
Old 01-05-2025, 03:26 PM
SS69chevelle SS69chevelle is offline
plugs will be similar if not the same, three in trunk, 4 in the passenger area. plugs should have a stamp on them usually a letter and numbers. the inner wheel houses are flatter, on top when installed, than a couple sorry dont have a pic, if you google convertible chevelle restoration you may be able to see it on the body, in think it is done to give the top frame clearance. hope this helps, good luck, andy
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
The Following User Says Thank You to SS69chevelle For This Useful Post:
olredalert (01-05-2025)
Old 01-05-2025, 04:40 PM
daveg's Avatar
daveg daveg is offline
Inner and outer wheelhouses are different on converts.
Drop off is same.
Rubber plug in front of drop-off should be same.
