Old 01-25-2025, 12:35 AM
70post 70post is offline
Spend the extra $ (if required) for at least one (two is better) FLOOD LAMPS inside the cabinet. Really helps you check your progress w/out having to open the door. I have one flood lamp in a couple cabinets here. Both came w/a florescent lamp/tube. I'll probably add another flood lamp to the larger (TP Tools) cabinet...one hanging on the L side ceiling and another on the R side. You can also go to HDepot, etc and get the wiring box, bulb fixture, etc and do that yourself for less $ compared to buying the floodlight kit from TP Tools, etc.
Patton Glade
70Post Restorations
Austin, TX
The Following User Says Thank You to 70post For This Useful Post:
RPOLS3 (01-25-2025)
