Old 01-28-2025, 12:49 PM
I know it would be a very long haul, but it would be so cool to see this car at the Super Car Reunion.
PeteLeathersac (01-28-2025)
  #122
Old 01-28-2025, 01:01 PM
As an SCR sponsor, I think that is a requirement.
Have they set a date for this year yet ??
  #123
Old 01-28-2025, 08:54 PM
Chuck_Burg's Avatar
SANO!!!!!!
Old 01-29-2025, 01:20 AM
Jeffp920 Jeffp920 is offline
That is one clean build. A Lot of good ideas under there. Looking real nice.
Old 05-09-2025, 01:42 AM
napa68 napa68 is offline
In the last few weeks, I've had an opportunity to get the Nova out. Like any new build, there are always a few bugs to work out. I assumed this would be the case, so there is no surprise on my end.
When Wayne and I consummated our deal, we were in the dead of winter. Wayne was kind enough to change the coolant over to an antifreeze blend. Given the time of year, Wayne was not allowed the luxury of time and environment to get the cooling system bled out properly. Wayne did warn me these siamese bore blocks can be a bit tricky to get the air bled out of them properly. There was an issue where the temp would be just fine, then take off......to only come back down to 180, and repeat. Wayne and I had a nice conversation to which he gave me a few tips. I have made some significant improvements in this regard, but I still feel there is room for improvement. I also played around with some timing adjustments, and that showed some gains as well. As many of you know, a combination like this is far from a plug and play.
The brakes are awesome in the car and can back up the performance of the car (more on that later). The pedal pressure is a bit firm. I feel I can improve on that and have a different bore master cylinder. The front suspension combination is firm and holds the road wonderfully. Wayne was quick to point out he wanted as much caster as reasonably possible given the "purpose" of the Nova. Wayne had done the alignment in his shop. I've got to say........this is impressive. I will get the Nova in front of a good local alignment guy to dial that in a bit more.
So the last question that everyone seems to ask.........how's that thing run?
Well......in short.......it's F'n silly. The engine's idle is somewhat docile (if you want to call 1100 rpm docile) and has good manners in a driving scenario. The experience Wayne has in these types of builds is blatantly evident. Between the carb, the converter, and the gearing......the car just works. Mash the loud pedal.......you best be paying attention. If I "whack" the tires hard, they get nice and sticky. Then it's game on. The rear suspension works although the motor can still overpower the "hook". A perfect street car
As I had mentioned in a previous post, the fit, finish, and eye for detail on the car can only be appreciated in person. If you spent just an hour looking around the car by yourself, I think many of you could see and appreciate what I see.
This is not an easy car to build. Even more difficult yet to get the project to execute as planned. Wayne has built a killer car here. Furthermore, he was a gentleman to deal with, and the end product was everything he made it out to be.
So, what's next you may ask? I'll share this. Once I am comfortable with the car and happy with all of the little details, I foresee a next stage. Backing up a little bit, one of the questions I asked Wayne when making our deal on the Nova, "if you kept the car, what would you do?" Without hesitation, he said "a stick". (Great minds think alike).
As I write this, a mutual friend of Bill Wente and myself reached out a couple of days ago. One of his friends (Brian's friend) has a brand new M23 from Midwest Muncie (here in Wisconsin) that he is not going to use. These transmissions can handle 800hp on a sticky tire. In order to package everything the way I'd want to, this will be far more than cutting a hole in the floor for the shifter. I would want to keep the bench seat, yet place the shifter as close to me as possible. That would require some surgery on the seat. Then, a stick with this kind of power can hurt a car that is not properly reinforced. The body on this car, the panel fit, and the way it drives is to die for. I have to research my options before moving forward.
My parting comment is this. Jake Dykstra........you are not the only one dealing with project creep
As my last side note in this post....I think Dave Dykstra found the secret cam grind that's in the 565
The Following 12 Users Say Thank You to napa68 For This Useful Post:
67since67 (05-09-2025), 69M22Z (05-09-2025), big gear head (05-09-2025), cheveslakr (05-09-2025), Crush (05-09-2025), dykstra (05-09-2025), kwhizz (05-10-2025), L78_Nova (05-09-2025), PeteLeathersac (05-09-2025), Roger M (05-09-2025), RPOLS3 (05-09-2025), Tenney (05-12-2025)
  #126
Old 05-09-2025, 02:31 AM
Very cool car.
Do you have an evacuation kit for the cooling system ? I have the Airlift brand and it eliminates trapped air in hard to purge systems.
There are MANY different brands and styles now available from several years ago when I got this one. It uses shop air to evacuate and then pulls the mixed coolant back in from a pail.
RPOLS3 (05-09-2025)
  #127
Old 05-09-2025, 02:39 AM
Originally Posted by Too Many Projects View Post
Very cool car.
I've got that from a couple of LS builds. That helped. It can be better IMO
69M22Z (05-09-2025)
  #128
Old 05-09-2025, 02:56 AM
I agree and it looks like there are better kits out now, not so dependent on all the adapters and such to leak.
Old 05-09-2025, 10:02 AM
Smile
Thank you for the kind words Tim. I totally agree with your comments on getting rid of the trapped air inside that big bore Dart block. I didn’t have an evacuation tool so what I did (pre-antifreeze) was to jack the car up front and then back and then from side to side to “shake them loose”. 😅It was never perfect but I’m positive Tim will nail it.
The car will be an absolute riot with a stick! It was my plan from the very beginning but I chickened out, even though I had (at the time) a dual disc Tilton clutch, a scattershield with an adjustment window and a fabricated rod end linkage plus all of the little parts. Getting the right shifter will be the biggest task. A Long inline (a better built, modern version of the old VGate) would be the best but I’m not sure if it will work without considerable tunnel surgery. Next best I think would be a Long H pattern (a better built, modern version of the old Super Shifter), but I never did figure out if it requires cutting of the sheet metal crossmember inside the tunnel. So…get your tape measure out Tim ! The fun reward will be worth it.
Honestly I’m glad someone like Tim has the car because he has the skills and knowledge to deal with it. The Nova is seemingly tame but at W-O-T it’s a ferocious beast and has the capability of biting back in the wrong hands.
Have fun Tim. The rush as the tach crosses 6500 RPM is, well, considerable! I miss you Nova Jane. W
The Following 4 Users Say Thank You to Arrowsmith For This Useful Post:
dykstra (05-09-2025), napa68 (05-09-2025), PeteLeathersac (05-10-2025), RPOLS3 (05-09-2025)
  #130
Old 05-09-2025, 10:34 AM
scuncio scuncio is offline
Great car, appreciate you keeping us in the loop as you refine it!
Wayne, nice attention to details. Few know how much effort it takes to get that level of appearance on a chassis. Wow.
The Following 4 Users Say Thank You to scuncio For This Useful Post:
napa68 (05-09-2025), PeteLeathersac (05-10-2025), RPOLS3 (05-09-2025), Steve Shauger (05-11-2025)
