Does the T.I. system not use the cloth covered resistor wire to the +side of the coil? The illustration on line looks like it doesn't but has a separate white wire coming from the T.I. box. I tried firing it up for the first time and it seems like it wants to start after you stop cranking and return to the run position. I put an HEI in it and it started right up. Is there in fact a separate wire that goes to the positive side of the coil instead of the resistor wire?
70 Chevelle Vert L34 M21 28-A 791 70 Chevelle Cpe LS6 M40 14-14 756 70 Chevelle Cpe L?? M?? 926-99616 755 69 Chevelle Cpe L78 M21 71-B 756 70 Chevelle Cpe L34 M20 48-48 796 |
The K66 ignition needs constant 12v supply. The resistor wire is bypassed.
Here's how it was configured for a Camaro. Since it was a Corvette option, there must have been a dedicated harness for it.
![]() Quote:
Let's throw this in for good measure......
Thank you Sir.
BlackLS5, Would you please contact Chuck Sharin at Tu 5 Three, Tu 6 Three, 5 One Nine 0
Chuck Sharin [email protected] Auburn,WA (30 miles South of Seattle) 70 Camaro R/S Z-28, L-78, R/S SS 69 Camaro COPO "recreation" |
Thread Tools | |
Display Modes | |
