Old 05-22-2025, 03:40 AM
YenkoBird YenkoBird is offline
Default Yenko 427 Engine Information
I have a 427 L72 Yenko complete engine in my car. Does anyone have any information or links that can provide more info. It has the Yenko located in the block casting front drivers' side on an angle. The heads are cast 3946074. The intake has the winter foundry marks. I understand this block casting was from earlier blocks, possibly 69?
The Following 2 Users Say Thank You to YenkoBird For This Useful Post:
dykstra (05-22-2025), Pro Stock John (05-22-2025)
Attachments - The Supercar Registry IMG_6160.jpeg IMG_6135.jpg IMG_5920.jpg IMG_5906.jpg
Old 05-22-2025, 01:40 PM
LT1vette LT1vette is offline
That Holley has an odd choke linkage on it. Is there a part number stamped on it?
Old 05-22-2025, 03:21 PM
LetsFNgo's Avatar
LetsFNgo LetsFNgo is offline
It’s a 950 3 barrel list 3916. That’s the choke setup they used. A 1030(some say 1050) 4604 3 barrel is identical but uses dump tubes on the rear secondary flap instead of boosters.
AMC weirdo
The Following User Says Thank You to LetsFNgo For This Useful Post:
LT1vette (05-22-2025)
Old 05-22-2025, 05:28 PM
Hi... I've never seen one of these, thanks for the info.
Old 05-22-2025, 06:21 PM
William William is offline
Yenko sold ZL-1 block castings in the '70s, no complete engine assemblies. Disassembly would be the only way to determine build configuration.
Old 05-22-2025, 06:45 PM
From what I read, the castings with the Yenko on front right were early builds like in 69? Possibly from a wrecked Camaro? Also, the head casting numbers were on 69 ZL1's, I could not find if that was a standard head for years afterwards.
Old 05-22-2025, 08:00 PM
No ZL-1 Camaro had a Yenko block.
Chevrolet produced the last production ZL-1 block castings [3946052] early August 1969. Lockport [LC] did some 053 castings in the late '80s.
The 2025 Chevrolet Performance catalog still lists an 053 block casting, much improved over the original.
The 3946074 head was produced into the '70s.
The Following User Says Thank You to William For This Useful Post:
69M22Z (05-22-2025)
Old 05-22-2025, 08:54 PM
luzl78 luzl78 is online now
William, I was looking for the 053 block,couldn’t find it. Do you have the part number for that block? Thanks. Jeff
Old 05-23-2025, 04:39 PM
Since this is a complete motor, with a early Yenko block, would I assume it came out of a car Don had replaced the motor with. Did he sell complete motors in the 70's. My gut tells me this could be a late 68 or 69 motor but will search for some identification on it. It just has all the parts from a full motor that Chevy would have put in the ZL1 except it has the Yenko block. So little information out there. I have also been told so many different things. Thanks
Old 05-24-2025, 04:01 PM
What’s the casting date of the block and the heads?
