Old 06-16-2025, 10:33 PM
copo69's Avatar
copo69 copo69 is offline
Default 69 seat belt help
Have a ‘69 Biscayne that the plastic cover on the retractable seat belt has disintegrated and needs replaced. Does the belt mechanism need to be disassembled to pass buckle through. It doesn’t appear that it will slide over the buckle when installing new cover. It’s the same on many GM cars like the Chevelle.
Old 06-17-2025, 01:42 AM
You can pull it out, spin it 90 degrees while wrapping the belt tight to the clevice and it'll go, tight, but it'll go.
Old 06-17-2025, 02:02 AM
I've had 69 belts apart many times. More often than not, the plastic cover breaks, as it is a very tight fit over the metal base and the plastic is extremely brittle after 55 years. You can super-glue them back together and pray that they don't crack again when installing the new cover....that has worked for me.
EDIT: oops, I see now that you're working on the male end of the belt that's retractable, so forget what I said above. I did this on my former 69 Chevelle in order to repaint the retractor cover, and I think I did disassemble the retractor mechanism and remove the belt after removing the plastic cover from the metal base. What chevslakr mentioned above may work but I never tried it.
Bill Pritchard
Old 06-17-2025, 02:53 AM
LT1vette LT1vette is offline
Heat the plastic FIRST with a hair dryer....should work
Old 06-25-2025, 02:16 AM
Unreal Unreal is offline
I boiled mine.
The Following User Says Thank You to Unreal For This Useful Post:
olredalert (06-25-2025)
Old 06-25-2025, 08:35 PM
Originally Posted by Unreal View Post
I boiled mine.
----You read my mind, unreal!!!....Bill S
