OK. Thanks for the input. I am pretty much all set with good GM parts and was planning on using the single piston calipers as the 4 piston limit wheel choices due to the size of the calipers. One last question. I have a restored 9" booster done by Mike G ready to go. Have been toying with the idea of using an 11" 67 up style which I would have to buy. Would the 11" perform any better than the 9"? as I am concerned with having enough vacuum? Or just stick with the 9"? I also have good 2 piece rotors that I was going to use which I believe will work with the single piston calipers but not sure about that? Thanks again!
When I first bought the parts from In-Line, I ordered the '67 booster as well, not knowing the '66 should have a 9". I drove the car with that booster for a few years until I swapped it for a correct 9". Never noticed a difference, but it certainly looks better under the hood..
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
BillD (07-03-2025) |
Thread Tools | |
Display Modes | |
