Beautiful can't beat a good original 62 Corvette. Here is our 1962 Original Fuelly 26K original miles all original except one old Lacquer repaint in 1972 and the vintage rocket RPM wheels
The Following 16 Users Say Thank You to Nasblu For This Useful Post: | ||
1967 4K (07-10-2025), 1967Z28 (07-11-2025), 1969L89 (07-12-2025), 67since67 (07-10-2025), 69Z11Pacer396 (07-15-2025), big gear head (07-11-2025), dykstra (07-11-2025), MosportGreen66 (07-13-2025), napa68 (07-10-2025), PeteLeathersac (07-11-2025), ragtop (07-10-2025), roadster (07-14-2025), RPOLS3 (07-11-2025), scuncio (07-11-2025), Steve Shauger (07-10-2025), Tenney (07-11-2025) |
![]() Quote:
The Following User Says Thank You to napa68 For This Useful Post: | ||
Nasblu (07-10-2025) |
----This is the way a 62 should be be set up as far as I'm concerned. Love the wheel and tire combo. That puts your 62 over the top for me....Bill S
The Following User Says Thank You to olredalert For This Useful Post: | ||
Nasblu (07-12-2025) |
They are 670-15 tires.
The Following 3 Users Say Thank You to Nasblu For This Useful Post: | ||
While the transmission took a bit longer than anticipated, it is done and on the way back. I should have it Monday. The blocker rings on 2nd and 3rd were toast, and the front bearing was not all to healthy. 2nd gear itself did not look too bad, but elected to replace it with an NOS unit. Surprisingly, the shafts were MINT! Tom expressed some concern over that if the car was used as intended. With a little luck, this should be back in service EOD Monday, or Tuesday morning.
I still see spots of undercoating ![]() ![]() ![]() Last edited by napa68; 07-12-2025 at 04:19 PM. |
The Following 6 Users Say Thank You to napa68 For This Useful Post: | ||
dykstra (07-13-2025), olredalert (07-12-2025), PeteLeathersac (07-12-2025), Roger M (07-13-2025), RPOLS3 (07-14-2025), Tenney (07-13-2025) |
Thread Tools | |
Display Modes | |
