Old 03-25-2001, 04:56 PM
69motion 69motion is offline
Default 67 DATED / 512 BLOCK
i have a 67 ,512 427 cu in. block what could it have come in thanks jeff
Old 03-25-2001, 07:31 PM
GMH454 GMH454 is offline
Default Re: 67 DATED / 512 BLOCK
Can you please put up all the numbers. If the 512 is the last 3 digits then this would be the first of the blocks cast for the 454. They were introduced after the 270 and in late 1968 although they may not have first been dropped in cars till early 1969. The four bolts by that time had a back log and sat on the shelves for quite a time before installation. Can you list pad numbers if any and casting dates. On a 512 it should be the top of the bellhousing on the other side to the casting no.
Old 03-25-2001, 09:22 PM
COPO COPO is offline
Casting dates on the early 512's are on the side of the block.
Old 03-27-2001, 11:17 AM
block# 3963512 date L 22 67 (early 68) the broch marks are orig block has never been stamped, 4 bolt ,large plug on side. Ive owned it 20 years i got it from a local racer any help will be app. thanks jeff
Old 01-20-2005, 09:53 AM
rpoz11's Avatar
rpoz11 rpoz11 is offline
Try DANA/TA on this site; I recall he is rather knowledgable on blocks...
Chavez Ravine
