I peel back the factory mastic sound deadener and I find a right rear side marker lamp bezel face down against the floor pan:
Can you imagine how many technicians tried to figure out that rattle in the floorboard over the entire warranty period of this car? It was obviously put there by a disgruntled UAW worker just prior to the six month strike that shut down the Norwood plant for the rest of the model year in 1972. (as you may recall that was the reason there were so few 72 Camaros and Forebirds built)
That became an option on the Delorean later on as well.
I believe it was originally RPO 0U812 ![]() |
I just spent the entire day with a pressure washer underneath the Tran Am. The entire original floors are still covered in their factory red oxide primer with white overspray. Not a speck of rust underneath the car (other than the trunk well but that is standard on any 2nd gen F-body). There was no undercoating so all I was removing was the years of road grime. Just amazing! I found the factory paint marks on the suspension pieces, the part number tags on the coil springs. Even the leaf springs had the part numbers still stenciled on them in white paint. Now I know how archaeologists feel when they unearth a new dinosaur.
And here we are: Greasy Man and Spotless boy, about a half a second before my wife abducted him and dragged him away from grime-central. She just doesn't know what fun really is!
That must have been fun !!!
Don't mess with old farts - age and treachery will always overcome youth and skill! Bullshit and brilliance only come with age and experience. |
did the same thing on the '68 last fall..I came up with laying old king size sheets under the car to keep all the grease and dirt off the driveway...sure made cleanup fast roll them up toss in the garbage, rinse a little all done sure beat cleaning the driveway after the car trick, I always had a gravel area for messy stuff until this place now I have to think before making a mess..lol.
Bud. |
Looking good--you really realize the details and effort that goes into a restoration of this type when you do it yourself. You've got quite a journey going there.
Morris
https://picasaweb.google.com/1070244...e?noredirect=1 |
I get more of a kick out of the restoration process than I do after it's finished and just sitting there. It's like a jigsaw puzzle; what do you do with it when it's all finished...take it apart and do it again? This car is kind of neat in that I am keeping as much of it in its original form. The floors will remain in their original (now clean) state. Other than stripping and straightening the upper sheetmetal and replacing a portion of the trunk well, the car will be a "reassemblation" not really a restoration. -a new challenge for me.
Here is some of the underside's original finish: this is the inside of the trans tunnel if you were laying on the ground looking up.
Thread Tools | |
Display Modes | |
