Old 05-25-2005, 05:42 AM
Default Re: Spray Day
That's some nice work Steve,with great results.
njsteve njsteve is offline
Passenger side, front floor with the overspray visible. The factory white overspray was everywhere underneath this car.
Old 05-25-2005, 05:45 AM
Driver's side floor front area.
Old 05-25-2005, 05:47 AM
Top of cowl, blackout area.
Old 05-25-2005, 05:49 AM
Driver side front cowl area. The black is flat black, not semi-gloss. Note the heavy runs in the black paint.
Old 05-25-2005, 05:55 AM
The inside of the tran hump where the shifter goes through. This area had a random coating of the same body shutz (heavy undercoat) that the rear wheel wells had. An interesting note: It appears that the body shutz in the rear wheel wells was applied before paint. The undercoated area is painted white and when a section is peeled away, shows red oxide primer underneath.
Old 07-03-2005, 04:22 AM
I spent the day powerwashing the frame and then using some paint stripper to get the real yucky stuff off. Look what I found under the paint by the passenger side rear of the subframe. It looks like it was hand-printed with a magic marker "5236 44." Does this correspond to anything?
Old 07-03-2005, 04:23 AM
Here it is upside down so you dont pull a neck muscle looking at it.
Old 07-03-2005, 05:53 AM
And here is a close up of the front coil spring. As you can see it was painted black originaly and still has the part number tag attached, #3988100 AX. Does anyone know if this tag is reproduced? I couldnt find it on Jim Osborn's site.
Old 07-05-2005, 12:26 AM
tirebird tirebird is offline
Default Re: 72 TA : New Project
Steve:
If you want the original factory order sheet and dealer info. on your car there is only one legitimate source, Pontiac Historic Services.
http://www.phs-online.com/
John
1971 BFG "Tirebird"
