Old 05-25-2005, 05:42 AM
njsteve njsteve is offline
Default Re: Spray Day
Passenger side, front floor with the overspray visible. The factory white overspray was everywhere underneath this car.
Old 05-25-2005, 05:45 AM
Driver's side floor front area.
Old 05-25-2005, 05:47 AM
Top of cowl, blackout area.
Old 05-25-2005, 05:49 AM
Driver side front cowl area. The black is flat black, not semi-gloss. Note the heavy runs in the black paint.
Old 05-25-2005, 05:55 AM
The inside of the tran hump where the shifter goes through. This area had a random coating of the same body shutz (heavy undercoat) that the rear wheel wells had. An interesting note: It appears that the body shutz in the rear wheel wells was applied before paint. The undercoated area is painted white and when a section is peeled away, shows red oxide primer underneath.
Old 07-03-2005, 04:22 AM
I spent the day powerwashing the frame and then using some paint stripper to get the real yucky stuff off. Look what I found under the paint by the passenger side rear of the subframe. It looks like it was hand-printed with a magic marker "5236 44." Does this correspond to anything?
Old 07-03-2005, 04:23 AM
Here it is upside down so you dont pull a neck muscle looking at it.
