Old 01-15-2006, 04:16 AM
71-LS6 71-LS6 is offline
Default Re: 72 T/A progess
Hey Steve, that was a pretty neat trick with the leaf spring stencils. Looking good!
Steve H.
industrial art collector
Old 01-15-2006, 04:51 AM
njsteve njsteve is online now
When all else fails, use the cranium!
Old 01-16-2006, 01:08 AM
Got the rear end installed, along with the sway bar and shocks. I ended up painting a set of KYB gas shocks in the GM grey color (did the same in the front). This way they won't stick out so much as not being original.
Old 01-16-2006, 01:09 AM
I started to clean up the driveshaft and noticed that the original paint marks were still there, under the grey paint someone put on. Some careful cleaning and here's the remnants: From the front of the driveshaft the order is orange, white, then yellow. (This stripe scheme is corroborated by the '72 repair manual list as the correct code for the M-22 and M40 driveshaft for 1972) The stripes are brushed on and they are 1/2" wide with a 3/8" gap between them. (You can still see the brush marks in the paint) The front stripe is 19-3/8" from the front weld seam and the rear stripe is 22-1/2" from the rear weld seam.
Old 01-16-2006, 07:33 AM
yellowjudge yellowjudge is offline
Great pics, & very informative
Old 01-17-2006, 02:43 AM
I spent a few hours chemically stripping the paint off of the driveshaft and then polishing it with the coarse wirebrush disc on my bench grinder. It worked very well. The finish matched the shiny areas under the stripes exactly. I then restriped it with one shot striping enamel and a brush. I let the paint dry overnight and then installed the U-joints and sprayed the whole assembly with the wax based Nyalac metal preservative. It works pretty well at keeping natural metal from rusting.
Old 01-17-2006, 03:46 AM
DarrenX33's Avatar
Steve this is incredible work. I am blown away. Geez where the hell have I been?
1969 Z28
1972 Corvette
