Old 01-12-2005, 08:21 AM
DarrenX33's Avatar
Default Radiator flush.
Getting the crud out of the radiator. Has anyone used Lime-A-Way or CLR to clean them? I have heard this works like a charm. Want to be sure though.
1969 Z28
1972 Corvette
Old 01-12-2005, 04:13 PM
Default Re: Radiator flush.
Darren, Take the radiator out and take it to a shop.Let them flush it and if it does leak after the flush, they can repair it. It is worth the little work because when you get it together and it leaks I will here that Sicilian temper from here. Won't even cost much. An ounce of prevention is worth a pound of cure!
Old 01-12-2005, 04:16 PM
DarrenX33's Avatar
Radiator doesn't have any leaks. I just wanted to get some of the gunk out.
1969 Z28
1972 Corvette
Old 01-12-2005, 05:34 PM
Bring it A-Len over here on Ogden,next to where that Deuce was,while you have it out of the car.
Lenny will flush it,& test it all for a minimal charge.
He is very good,& it will insure you are good to go..
Old 01-12-2005, 06:23 PM
DarrenX33's Avatar
I'm getting the feeling this is something I shouldn't do myself.
1969 Z28
1972 Corvette
Old 01-12-2005, 06:32 PM
You can do it yourself but it is usually less than 100.00 to have a rad shop do it and they usually do a good job. Just make sure you tell them to not lose the tag.
Old 01-12-2005, 07:11 PM
DarrenX33's Avatar
Thanks Charley.
1969 Z28
1972 Corvette
Old 01-13-2005, 04:52 AM
NCGuy68 NCGuy68 is offline
If the radiator has crud in it, most likey the entire cooling system does as well.
Do yourself a favor and drain/flush the engine block Pull the drain plugs located on the lower block. You may need to dislodge the crap in the block after the plugs are removed. You'll be amazed at what comes out!
Its a easy Saturday task using the right tools and well worth your time and effort.
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 01-13-2005, 05:59 AM
[/ QUOTE ]Do what he tells you Darren and stop asking! Should have been done by now! Or you won't get your cheese steak.
Old 01-13-2005, 09:09 AM
DarrenX33's Avatar
Oh boy. All I wanted to do was put the heads on and paint up the motor.
1969 Z28
1972 Corvette
