#101
Original NOS weather head brass oil line fitting. 67 thru 70 solid lifter big block.$22.50 PPFF
#102
Speedometer cable adapter to transmission retainer with O stamp and mounting bolt which has unique flat head U-design. $15 PPFF
#103
Original unrestored complete set of 12 M head marking exhaust manifold bolts. $60 PPFF ************SOLD************
#104
5 exceptionally nice R head marking exhaust manifold bolts for small block. $30. PPFF
2 of them even still have some original paint on them. |
#105
Excellent original restored small block fuel pump mounting bolts and fuel pump plate to block mounting bolts.
These are the 9/16 hex design fuel pump mounting bolts with the flying f head marking and the fuel pump mounting plate bolts have SEMS for their head marking. I've included a picture to show why the mounting plate bolts are unique to this application and most people have the wrong ones. The fuel pump mounting plate bolts are a little bit longer than regular timing chain cover and small block oil pan side rail bolts. And that's to make up the difference for the thickness of the plate itself that they're mounting. $22.50 for the set. Two sets available. |
#106
Extremely nice alligator skin high performance small block water pump bypass hose. Extremely nice very flexible and pliable no cracks. On the one end of very little corner was tucked in when it was clamped but it will still seal perfectly as you can see the side screw clamp Impressions above it. $22.50. PPFF
#107
Headlight washer hose tees. They don't reproduce the correct style for this application. Very hard to find originals.$17.50 pair. PPFF
#108
Edited
#109
Thanks SYC!
***********************************this thread is closed-all items have either been sold or moved to other threads******************************************* ** Last edited by Enoch; 01-15-2021 at 10:43 PM. |
