1987 Grand National T- Tops $12500.00
Extremely clean straight 1987 Buick Grand National / (WE2) with (G80) code Posi rear end. This car has been garaged kept and covered. It has never been raced, nor has it been beat on. It’s tuned with boost set at minimum spec. No rust or rot anywhere. Body is Super straight with no dings. All body lines line up perfectly. It was stripped down to bare metal and professionally repainted about 3 years ago due aged worn paint. The paint is very flat, smooth, shines incredible, and looks like glass. It has been driven about 600 miles in the past two summers, presently about 81k. I have never driven it in the rain or winter.
Interior is close to mint with original radio concert sound and working power antenna. Runs and drives beautiful and sounds very strong with no unusual noises. No smoking no leaks! Turbo Spools nicely and goes down the road straight, with no pulling, shaking, or vibrations. Very quick with firm accurate shifts. . . ENGINE IS ALL STOCK. Due to the age of these cars I have done the recommended maintenance upgrades for this relatively stock GN. (Listed below). I do have all original parts that will go along with the car. You can drive this car safely anywhere… Here is a list of NEW ITEMS... BF GOODRICH TIRES ALL AROUND BILSTEIN SHOCKS FRONT UPPER AND REAR CONTROL ARM BUSHINGS SWAY BAR LINKS IDLER ARM COMPLETE TRANSMISSION OVERHAUL WITH ART CARR SHIFT KIT NEW D5 TOURQUE CONVERTER 2200 STALL (FACTORY) BILLET SERVO & HARDENED INPUT SHAFT ALTERNATOR 4 CORE RADIATOR BATTERY INJECTORS LUCUS #30 (CONSIDERED TO BE FACTORY REPLACEMENTS) ACCUFAB AFPR RJC POWER PLATE RJC BOOST VALVE / SET @ 15PSI WALBRO FUEL PUMP / HOT WIRED MAGNAFLOW STAINLESS STEEL DUAL EXHAUST T-TOP SEALS INTERCOOLER (CLEANED AND FLUSHED) REAR MAIN SEAL ENGINE MOUNTS TURBO TWEAK STREET CHIP (93 OCTANE) COLD AC / CONVERTED R134 NEW BRAKES ALL AROUND ADJUSTED WHEEL BEARINGS VDO BOOST GAUGE ALL FLUIDS FLUSHED AND REPLACED. VACUME HOSES SCANMASTER SCAN TOOL ALUMINUM COLD AIR INTAKE /K&N FILTER COIL PACK / PLUGS / WIRES / PCV VALVE /FUEL FILTER SERPENTINE BELT TIE ROD ENDS O2 SENSOR ADJUSTABLE WASTEGATE TURBO HEATER CORE 160 THERMOSTAT That’s it…. You wont be disappointed with this purchase. Very sharp GN, and hard to find in this shape. This is the original advertisement when I purchased this car this past January, I have driven it about 600 miles since CALL George 914-438-7185 [email protected] -- Poughquag, NY 12570 -----12,500. http://s64.photobucket.com/albums/h1...ue/Buick%20GN/
"I never think of the future. It comes soon enough." - Albert Einstein |
Re: 1987 Grand National T- Tops $12500.00
George that is a Real Nice GN, A friend let me drive his 87 GN 3 years ago and I was hooked, I had to have one. These Turbo Regals are an absolute blast to drive. I brought a 900 mile GNX which I feel guilty about driving so it is a Garage Queen. I should have brought one with some miles on it. I am trying to work a trade for a GNX with some miles so I can enjoy the car.
Good Luck with the sale….
Kentucky Gold 70 SS/RS L78. 81 Z/28 Silver/Silver Int 09 G8/GXP #992 98 Pontiac GTP Daytona Pace Car #605 90 Olds Touring Sedan SUPRCHRGD L32 83 El Camino |
Thanks Mark, the six cylinder turbo in these cars is amazing. I'm suprised Buick never continued with a model similar.
What I like about my '87 is the mpg. 27 on the highway. That's pretty pathetic on GM for what the new cars are getting compared to a '87. Shame on you GM. No wonder your sunk and need the taxpayers to bail you out.
And the politics sure didn't help especially when the GN was the quickest production car in '87 that would blow by the Vette. FBI ordered a bunch and swapped the tires and got rid of the limiter and used them to chase Porsches. And then the end came in '87 for the GN because it didn't look good in front of the Vette that a cheaper car could blow the doors off a Vette. Nice car and good luck on the sale.
1970 Z28 M22, 3.73, Z21, Z87 |
I remember getting pulled over for speeding by the Connecticut State Police in 1989. At the time, they had a fleet of these turbo Buicks as their pursuit cars. I guess it wasnt much of a challenge for them to catch my 3/4 ton Suburban.
