Old 11-23-2010, 10:43 PM
njsteve njsteve is online now
Default Re: 72 TA : New Project
It's been an eventful couple of days here! Nothing seems to be easy lately. DAMN GREMLINS!
After I did the jet and rod swap, I reinstalled the carb and took it for a ride: it felt good but started popping at 4,000 rpm. Thought it was a jetting issue until I got home and sat there idling and it then idled down to zero and wouldn't restart, just cranked with no spark.
Typical! So I swapped in a brand new extra set of Accel points since the ones in the distributor looked fried...again. (Unfortunately, I had previously reinstalled that damn Pertronix coil which I had swapped back in after noticing the original Delco coil was leaking oil last week. I am beginning to think that that Pertronix coil is supposed to have its own ballast resister, even though the box said it didn't need one.)
Anyway, I couldn't get the damn thing to spark! So last night I bought a new coil at the local Napa store, still no spark. So then came the ignition parts replacement with known good parts to try to work through what went bad. Points, condensors, rotor, cap. Even tried a new primary lead wire from the neg coil terminal to the points since I have seen those break internally, before.
Turns out the brand new Accel points that I had swapped in, were defective. They were brand new in the box, but for some reason wouldn't work - looked like the rubbing block was too short. Swapped in another condensor, still no spark. Finally, I filed down an old set of used points, installed them and it miraculously fired up. Oh, that was after I installed the rotor backwards (yes, it is possible) and almost blew the roof off of the garage. (Lucky, the car has a shaker hole in the hood, otherwise it would have one now!) All in all, a very long day, yesterday. Bought a new set of Napa points this morning and replaced the old set. Started up fine once the dwell was set.
So, the end result is that I put in the #74 jets and the #44 metering rods which were almost an exact 10% jet/rod size increase in richness, along with the red power piston spring, all from Lloyd-TX, a 455HO fanatic on the Performance Years website. This replaced the factory 71 jets and 43 rods. BE secondary metering rods, replacing the leaner stock CR rods. Accelerator pump and spring from Cliff Ruggles. Timing set at 8 degrees initial at the moment. Running with the vacuum advance routed directly to the manifold vacuum nipple off the back of the carb, separate from the TCS system.
Whoa Nelly! That really woke this thing up. She definitely screams now. No more fading, pulsing or flat spots in the mid and top range. She just keeps pulling. I chickened out at around 5,000 rpm, since I was running out of highway rapidly - but she was still pulling. I would estimate it was a good 30 horsepower difference between the stock super lean setup and Lloyd's recipe. Very seemless transition to the secondaries. The car's nose just rises up off the ground immediately. Oh, and the spark plugs actually have a little color on them now, from the super lean, bright white, porcelain, before.
By the way did I mention that this car gets really bad gas mileage? or is it my driving technique? I went through half a tank and only went 35 miles.
Old 11-25-2010, 02:29 AM
Any electrical gurus out there?
OK, so I figured out the reason I keep burning up the ignition points. I just don't know how to remedy the problem.
Just out of curiosity I decided to check the voltage at the positive terminal of the coil (the black/pink resistor ignition wire and the yellow starter solenoid wire that are crimped together) when cranking versus when running.
It is completely opposite of what it is supposed to be:
When cranking it shows 9.2 - 9.6 volts. Which I imagine is a full 12 volts but reduced by the amount of juice it takes to run the starter motor.
When running it shows around 12.2-12.4 volts.
This is the opposite of what it is supposed to be doing! It should be 12 volts during crank and 9 volts when running. So those full time 12 volts are frying the points.
I just swapped out the ignition switch under the column thinking maybe it was defective but no change. I checked the starter solenoid and it is wired properly with the purple, and yellow wires in their proper position.
Anyone have an idea on this? Is the resistor wire not resisting?
The engine wiring harness was supposed to be the one for the points ignition. (AmericanAutowire part# FB20530) I am wondering if they built me the wrong harness, and gave me the unitized harness instead.
I don't know if this is a blessing in disguise since I am going to upgrade to the M&H breakerless setup this weekend and their site says it will operate on the between 6 to 18 volts. I know that you need a full 12 volts running when you put an HEI distributor in, just wondering if the unitized harness has the same 12 volt running voltage.
Old 11-25-2010, 03:35 PM
napa68 napa68 is online now
It sounds to me like you may have the wrong harness. If the car were mine, I would take this route.
http://www.lectriclimited.com/mainpage.htm
The NCRS really seem to like this. Happy Thanksgiving!
Tim
Old 11-25-2010, 06:00 PM
That link goes to the main page. Are you referring to this?
http://www.breakerless.com/
LectricLimited sells them as well.
I ordered it on Monday. It should arrive tomorrow.
I dug out my original fried harness and checked the resistor wire, or what was left of it, and it read approximately 1.2 ohms resistance. It's just about impossible to get to the harness that's in the car since the bulkhead junction is buried under the power brake booster.
Old 11-26-2010, 01:56 PM
Yup! That's it!
Old 11-26-2010, 11:26 PM
Got the M&H breakerless conversion installed today. Started up just fine. Had to reset the timing, though since it was off by quite a bit. Must be due to the location of the sensor as compared to the points. Once the timing was set, she ran great.
I need to call their tech line on Monday to verify that running it on 12 volts won't be a problem. The specs on their website say it's good for 6 to 18 volts but I'd like to be sure.
I also need to call American Autowire Factory Fit, the makers of the wiring harness in the car and find out why their harness is not limiting the voltage the way it's supposed to.
Old 11-27-2010, 01:30 AM
Here's a couple photos of what the brand new points looked like after about 25 miles worth of test driving. Nice blue toasty finish from the full 12 volts all the time. The contact surface looks just as fried.
I ended up removing the old resistor section of wire from the original burned harness and if I cant get no satisfaction from the company that made the repro harness, I guess I will have to just attach the resister section to the repro harness and hope that reduces the voltage to an acceptable level.
