Old 06-01-2012, 11:08 PM
198plus 198plus is offline
Default 69 DZ 302 Engine ID.........
I have, what I think is the real deal (1969 DZ 302 Engine). I would just like some input on this to make sure it is a DZ 302.
Here's some numbers I have found.....Thanks for any help.
Front pad....... V0107DZ 1576024
Oil Filter....... 371 388 88N
Back of block........3956618
Heads........3927186
Couple pics..........
Old 06-02-2012, 12:53 AM
Default Re: 69 DZ 302 Engine ID.........
DZ is nothing but a suffix code. At least the block started life as a 302 it looks like. All those 4 bolt blocks could be in many applications. Have to see if the crank says 1178 on it. Its casted on the first throw up by the balancer. That is a Z/28 crankshaft. Rest of the stuff looks pretty good from here. DZ code looks like January 7th of 69.
Old 06-02-2012, 03:58 PM
If stampings are original and pad location correct for Vin, isn't there some digits missing between the 1 and 5?
9N if Norwood car?
VIN 124379N576024 ?
[img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 06-02-2012, 06:44 PM
I checked the numbers on the crank and it is a 1178 and main caps are 2482.
Old 06-03-2012, 12:45 AM
Main caps would be the same for a 350....I think? The crank being an 1178 is a 3&quot; stroke so you are good. Like I said DZ is a suffix code for a Z/28. Block is nothing special compared to other 4 bolt blocks.
Old 06-04-2012, 08:43 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
You need to provide a good sharp image of the pad with the stampings. Use the Macro setting on your camera (Flower symbol).
Then we can see if it is a &quot;real&quot; DZ-block.
Jan
Jan Suhr
Stockholm, Sweden
1969 Camaro Z/28 ProTouring
My Car My Book My Photos
Old 06-04-2012, 03:06 PM
[quote=jannes_z-28]You need to provide a good sharp image of the pad with the stampings. Use the Macro setting on your camera (Flower symbol).
Jan [/quote
Old 06-04-2012, 05:39 PM
x77-69z28's Avatar
i believe that 1 is an L or van nuys car. stamp looks good to me, but i am no expert.
Old 06-05-2012, 01:11 AM
x77-69z28's Avatar
just checked with a friend who has an 01B norwood z-28. his vin is 9n575XXX and his vin is by the oil filter. i dont think that after they changed the location, they would go back to the pad.
Old 06-05-2012, 01:51 AM
Fast67VelleN2O's Avatar
A different plant might have done things differently.
Day 2 is Life.
