Old 05-27-2013, 12:17 AM
Don_Lightfoot's Avatar
Don_Lightfoot Don_Lightfoot is offline
Default 69 Spring codes and numbers
When you look at the spring charts, for both Camaro and Chevelle, there are occasions where the same part number (seven numerical digits) is used for different codes (two alpha digits). Can anybody explain this? Appreciate it.
Specialized Chevrolet Decals
Old 06-02-2013, 03:58 PM
Default Re: 69 Spring codes and numbers
Hello Don,
Fronts I presume?
Many of GMs parts were interchangeable. GM did maintain unique part numbers (except for the recycling of 6 digit numbers in the mid 1970s). So if the part number is the same it should interchange.
The letter assembly plant codes could be be the same on shared parts, like engines. But would expect the assembly codes for the body specific parts would have their own codes for a similar part.
The Camaro and Nova shared part numbers. Not all were listed for each but as the subframe is the same they would fit.
I have not pulled the front springs from the Chevelle yet, but the A-arms and spring pockets seem to be the same. Could have been some overlap in specs.
Not sure if this helps you or not,
Greg
Old 06-02-2013, 10:24 PM
Certainly a bit of mystery still here, although I very much appreciate your response Greg. Your point about interchangeability is well taken. You are also right about being only the fronts for Camaros. I certainly can't speak for the accuracy of the spring charts I have, but here is what they are telling me.
<span style="text-decoration: underline">Camaro Front:</span>
3955709 - ED &amp; EK.
3955712 - EL, EM &amp; EQ.
3955725 - HA, HB &amp; HG.
3855727 - HH &amp; HJ.
3955722 - YA, YC, YH, YM &amp; YP.
<span style="text-decoration: underline">Chevelle Front:</span>
3952824 - AC &amp; AD.
3952808 - AH &amp; AI.
3952811 - AJ &amp; AO.
3952818 - GV, GW &amp; GX.
<span style="text-decoration: underline">Chevelle Rear:</span>
3952831 - BF &amp; BI.
3952828 - BE, BL, BM &amp; BU.
Old 06-02-2013, 11:52 PM
Hello Don,
Those look to be from an older parts book. One where they ran out of parts and sub'd the over the counter parts that were close.
As example EK was 3955710 but since they did not have that one, they list the 3955709. After 1970 they only listed two service front springs for the Nova.
You can see the full list of Nova Springs here along with a few calculators.
Spring Calculators and Charts
No Chevelle ones yet, but in the order book when I find time.
Greg
Old 06-03-2013, 12:14 AM
Well Greg, that certainly seems to be a logical explanation. Unfortunately there is no date on my Camaro illustrations. Thanks again pal.
Old 06-03-2013, 01:18 AM
Donnie's Avatar
Donnie Donnie is offline
Greg, let us know when you get the Chevelle chart finished.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 06-06-2013, 05:33 AM
Kurt S Kurt S is offline
I have the oldest parts listings I can find and they already had superceded many part #'s. Maybe some were never available for service. http://www.camaros.org/suspen.shtml#spring
Kurt S - CRG
