Old 03-23-2016, 08:10 PM
Woj's Avatar
Woj Woj is offline
Default Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
Looking good Ryan. That frame cleaned up pretty well.
Keep up the good work.
Phil Woj.
Old 03-23-2016, 08:40 PM
Ryan1969Chevelle's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Woj</div><div class="ubbcode-body">Looking good Ryan. That frame cleaned up pretty well.
Phil Woj. </div></div>
Thanks Phil:-)
I get a little surprised what I don't know......... I don't even know what I don't know:-) Dangerous:-)
I am super excited about the condition of the frame and suspension pieces:-)
Ryan
PS: Engine builder visits are on hold for two weeks, I am not pushed for time and one builder is away for two weeks so I will resume when he returns.
Old 03-23-2016, 08:42 PM
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 03-24-2016, 12:49 AM
So I added a little fun to the build:-)
Tracker1 has the perfect addition to my W-31 a Hurst Ram Rod Shifter to go behind my Ram Rod 350:-)
This will be perfect on my M22!!
Ryan
https://www.yenko.net/ubbthreads/ubbt...ter#Post651641
Old 03-24-2016, 02:23 AM
Leave that cut up floor hump alone.....until you have this ready to install [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 03-24-2016, 02:32 AM
That's the new plan:-)
I have a new 4 speed hump section lined up and it will sit aside for a little while:-)
Ryan
Old 03-24-2016, 02:44 AM
Did you ask Tracker1 if the Ram Rod comes with bushing shims? You will have to do research.....if they are needed for your application on an Olds? I believe they are needed.
I will email you a picture of the bushing.
Old 03-24-2016, 03:08 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Did you ask Tracker1 if the Ram Rod comes with bushing shims? You will have to do research.....if they are needed for your application on an Olds? I believe they are needed.
Dan </div></div>
I will find out. I think I remember the part from Ricks RR:-)
Ryan
Old 03-24-2016, 11:27 AM
69 Post Sedan's Avatar
Dan </div></div>
Dan, that shifter and mount are the second design, same as mine, so it shouldn't need the bushings/spacers. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">Things are looking great Ryan. You will be stoked with the Ram Rod.
Jason </div></div>
^^^^X1000^^^^
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-24-2016, 02:45 AM
Ryan.......here's my two cents. If you don't mind modifying your tunnel......do it now cause you'll regret not doing it later and eventually, you WILL put the Ram Rod in. Ask me how I know. [img]<<GRAEMLIN_URL>>/scholar.gif[/img]
Kurt. [img]<<GRAEMLIN_URL>>/[/img]
