Old 09-12-2017, 01:03 PM
Turbo70Camaro's Avatar
Turbo70Camaro Turbo70Camaro is offline
Default CD ignition box Q's
Hey guys question on which CD box would be correct for my 70 camaro or which is preferred for the 1970 year...
Delta Mark 10
Motion/Jacobs
Old 09-13-2017, 01:45 AM
COPO COPO is offline
The Mark Ten box was on a '70 BM Chevelle that I owned. The diodes on the top of the box are dated which could also give you an idea of manufacture date.
Old 09-13-2017, 12:49 PM
Thanks for the response bud, I will be running it as a non functioning box under the hood so date codes are not crucial for me but thanks for the heads up. I'll post up numbers from the diodes I have a few of the Mark Delta's and Jacobs/Motion from new to used........
My car is a mix of new (EFI) and old so throwing some day2 parts under the hood........
Old 09-15-2017, 12:46 PM
Not much real estate left under the hood so I'm thinking of putting the Delta Mark box on the driver side inner fender, what do you guys think....
Old 09-15-2017, 01:04 PM
Holy Plumbers Nightmare, Batman.
Very cool.
Old 09-15-2017, 01:06 PM
Very cool.
Lmao thats what it takes to make 1100+whp on pump fuel
Old 09-16-2017, 03:07 PM
Bernhard Bernhard is offline
Wow!
Is the box going to be used or is it just for eye candy?
I always liked fire wall mounted ignition boxes but you are very tight on space for a good reason.
69 442 post bench 3 pedal
Old 09-16-2017, 10:37 PM
Eye candy and I like the look, trying to sprinkle in original, day2 and modern. Once I get the car on the ground and out I'll post up pictures.
Old 09-26-2017, 01:13 PM
Christmas came early for me...................................
Now where the heck do I put this thing it sticks out 3-1/2", no room behind dist. or to the left/right of it unless I go all the way above where the heater box use to be................
