Old 06-19-2019, 10:17 PM
Tidmack Tidmack is offline
Lol, mine starts to combust from time to time, too!
Originally Posted by Crush View Post
My Amazon Prime account is on fire!
Thx guys!
Old 06-24-2019, 01:02 AM
TIM,
Your paint is in very good condition as far as the amount of paint there... it could be polished using an orbital with a speed controller with a foam pad and some fine cut or start with swirl remover.
You are as long as you don't change the texture below the belt line you are good as far as NCRS
I ended up doing it to mine and yours is not NEAR as checked as mine is.
FWIW I was told that your car top flighted at the chapter level last spring southeast chapter.
Old 06-24-2019, 12:30 PM
napa68 napa68 is offline
Originally Posted by firstgenaddict View Post
TIM,
Interesting!
Old 06-25-2019, 03:41 PM
You can through the NCRS get your judging sheets - they have a charge for the service however the National NCRS show is in French Lick Indiana next summer so your car should be eligible for Flight judging there without any other signoffs or pre-qualifications (any flight certification within the prior 3 years gets you in (if I am not mistaken).
napa68 (06-25-2019)
  #25
Old 06-28-2019, 06:03 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Originally Posted by L_e_e View Post
In my opinion, throw the clay bar away and get a Eagle One surface prep mitt, superior results over a clay bar and 1/10 the time and effort to achieve them.
Google "Eagle One surface prep mitt"
I took your advise and bought the mitt and spray - showed up yesterday, might be able to test it next weekend. Thanks
Jake Dykstra
Dykstra Motorsports
The Following 2 Users Say Thank You to RPOLS3 For This Useful Post:
L_e_e (06-28-2019), napa68 (06-28-2019)
  #26
Old 06-30-2019, 07:39 PM
RPOLS3's Avatar
Tried it on my wife's daily driver - worked great. Can do the whole car in a matter of minutes.
Jake Dykstra
Dykstra Motorsports
L_e_e (06-30-2019), Tidmack (06-30-2019)
  #27
Old 07-01-2019, 10:43 PM
L_e_e's Avatar
L_e_e L_e_e is offline
Glad it worked out for you, I was convinced when I used it on a car with 40yr old lacquer paint that felt like sand paper when you ran your hand over it, 1/2hr later it felt like glass.
The Following 2 Users Say Thank You to L_e_e For This Useful Post:
olredalert (07-02-2019), RPOLS3 (07-02-2019)
