Old 09-24-2019, 07:15 PM
ALLZS ALLZS is offline
Default Correct 69 z balancer
Is this the correct balancer for a 69 z/28 THE STAMPED #IS 7708
Attachments - The Supercar Registry DSCN7271.JPG DSCN7270.JPG DSCN7269.JPG 69 Z28 Assemblyline Balancer.jpg
Old 09-24-2019, 08:36 PM
Yes it is,part #3947708.
Old 09-24-2019, 08:43 PM
Steve Shauger's Avatar
Administrator
Yes it is, except it's not assembly line correct. If you are restoring a car to show or for correctness that is not the balancer to use. If you are building a driver and only functionality is necessary that will work. Correct assembly line balancer pictured below.
www.yenko.net
www.vintagecertification.com
Old 09-24-2019, 10:37 PM
That's the balancer that I have listed in the parts for sale.
Old 09-24-2019, 10:49 PM
Default balancer
ok I see the difference it should be like this one I have . thanks guys for all the help
Old 09-25-2019, 11:30 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Assembly line balancer should be stamped 7708M.
Tim in NSW, Australia
Old 09-25-2019, 12:21 PM
yes the one I pictured has 7708M
Old 09-26-2019, 10:09 AM
ZLP955's Avatar
Can't make out the 'M', but assume that's on the grey balancer?
I have one stamped 7708E on my CE 302 and it is a later service replacement with the shorter fingers that don't extend out to the rubber.
