Old 12-17-2019, 03:14 AM
x77-69z28's Avatar
Default Caliper rebuilding.
Who is everyone using to rebuild single piston Camaro brake calipers? I used Lonestar in Texas to do my 4 piston originals on my 67 Camaro, but it doesn’t look like Ken does single piston. A good friend is doing his pace car and I’m trying to get him to keep his date coded originals.
Thanks
Buddy
Old 12-17-2019, 03:22 AM
Billohio Billohio is offline
I did my own. You can get pistons and seals at NAPA
Bill
Old 12-17-2019, 10:13 AM
X66 714's Avatar
X66 714 X66 714 is offline
I did mine also. Pretty easy...Joe
Old 12-17-2019, 01:13 PM
x77-69z28's Avatar
This pace car has been sitting for 20 years! Probably gonna need sleeves.
Buddy
Old 12-17-2019, 01:34 PM
Steve Shauger's Avatar
Administrator
Hi Buddy, I usually do my own but if they need sleeves I've used White Post with quick turn around. Locally Apple Hydraulics in Calverton, NY and you could drop them off.
www.yenko.net
www.vintagecertification.com
Old 12-17-2019, 02:16 PM
X66 714's Avatar
Buddy
The sealing surface is the piston, not the bore...Joe
SS427 (11-03-2024)
Old 12-17-2019, 02:29 PM
Administrator
Joe when a bore that is pitted you'll never get a it to seal. That is why they resleeve the bore. Most of the time I can hone the bore to remove minor rust/pitting. I can't remember the last time I had to replace a piston.
www.yenko.net
Old 12-17-2019, 03:06 PM
It was my understanding on the single caliper that the bore didnt do much since the seal edge is the piston.
Bill
Old 12-17-2019, 03:27 PM
m22mike's Avatar
m22mike m22mike is offline
100% correct, a little pitting won’t matter
The Following User Says Thank You to m22mike For This Useful Post:
SS427 (11-03-2024)
Old 12-17-2019, 04:19 PM
X66 714's Avatar
Right. As long as the pits aren't in where the seal goes. The seal goes in the caliper housing....Joe
