E-F
Emblems -fender (NOS) 302, bezel and Camaro – Post959 Emblems -fender original 302 emblems Eddie had taken off car late 60’s – Post1317 Emblems - trunklid Fisher #7752901 - Post1361 Emergencybrake cables - Post401 & hardware413 Emissionssticker radiator support – Post1187, 1188,Post 1238 Engineassembly #3830711 head gaskets, pistons, heads, etc. -Post 506 Engine cam,Crane blueprint specification – Post1130 Enginecompartment original ‘68Z (cook_dw) with air cowl plenum - Post1004 Engine dressup starting - Post 582& 608 Engine dynosheet - Post 531 Engine headbolts original - Post481 Engine mount#6258154 (not correct purchased 1979) -Post 484 Engine mountcorrect - Post 500& Post 505 Engine mounthardware original vs. reproduction - Post482 & 539 Engine oil pandrain hole “TR” bolt - Post43 Enginepainting at plant picture -Post 646 Enginepiston original - Post412 Enginestamping pictures -Post 168 Engine withtransmission going in subframe -Post 735 & 736 ExhaustGardner installation – Post1168 Exhaust pipehanger rear originals - Post554 Fan shrouds,original vs. (NOS) Service replacement – Post1087 Fender sidemarker bezel differences – Post70 & 71 Flashersignal Stat 175 - Post783 & 785 Fuel pumpAC40524 used on ‘68 Z/28’s – Post1260 Fuel pumporiginal bolts - Post201 Fuel pumpplate, black or bare metal – Post872 Fuses colorcoded – Post 1294
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com |
The Following User Says Thank You to Steve Shauger For This Useful Post: | ||
67 Nova Boy (02-05-2023) |
G
Gas caplocking (NOS) #986970 – Post62 Gas caporiginals riveted handle -Post 373 Gas caporiginals riveted handle look added to NOS cap -Post 546 Gas pedal#3920296 review - Post365 Gas lineclip #3881339 clip with screw #3886522 & #3841230 -Post 586 Gas lineclip #3881339 install how to -Post 608 Gas tankanti-rattle strips – originals -Post 269 &1143 Gas tankfiller neck cover and phosphate screw – Post1014 Gas tankfiller neck hose and hardware - Post298 & 300 Gas tankfiller neck hose hardware clamps original - Post302 Gas tank fillerneck installation - Post1014 Gas tank installed– Post 1143 Gas tanksending unit original vs. #19179532 Service replacement -Post 520 Gas tankstrap - original semi-gloss black -Post 251 Gas tankstrap and bolts with nuts -Post 268 Gas tankstrap original bolt vs. reproduction -Post 275 & Post425 Glassquarter windows and trim – Post1053 Glasswindshield with rear glass and trim – Post1127 & 1128 Glove boxdoor Camaro script removal and parts – Post905 Grille endbracket installation with rivet – Post1144 Grilleinstallation – Post1117 & 1152 Grillematched for original look gray and painted – Post1144 Grille prepfor paint (NOS purchased 1983) - Post957 Ground atgauge cluster housing (speedo/tach) - Post1139 Ground strapscrews #9420415 - Post595
H
Hardware#124829 Z-bar nut – Post1315 Hardware#272876 shackle nut phosphate – Post1301 Hardware#3831892 - Post427 Hardware #3873852beside #3747933 carb studs – Post1013 Hardware#3933052 10-24X1/2” AMK correct – Post945 Hardware#5959164 rear tail-light screws – Post980 Hardware#9418962 console screw – Post1043 Hardware#9420415 ground strap screws – Post595 Hardware#9780422 three different suppliers - Post748 Hardware andfastener list by part number - Post1253 Hardware-fender clips - Post302 Hardware spoiler– Post 1087 (Foundlater to be acorn nuts!) Headergaskets made as GM originals -Post 508 &1301 Header GM hardware- https://www.camaros.net/forums/3940585-post1308.html]Post 1308[/url]& 1309 Headers-Kustomreproduction - Post263 & coated Post 279 Headlight bucketsoriginal restored – Post1119 Headlightelectrical connectors original -Post 309 Headlight T3date stamping original – Post39 Headlight T3testing - Post 884& installed Post1152 Headliner installed- Post 1080 Heater box andcore dated 67L - Post485 Heater hose –Post 995 &NCRS information Post1042 Heater hosewith GM logo picture taken Summer ‘68 (cook_dw) (Note: Heater hose for 68 used GM logo & by early 69 modelschanged to grooved) - Post1004 Hood bumpers- original vs. reproduction - Post1073 Hood hinge#3910668 comparison original to Service replacement -Post 269 &270 Hood hingeto fender screw differences – Post1254, 1255& 1256 Hood hinge andlatch restored - Post361 Hood hingehardware #9419301 - Post480 Hood latchparts - Post 256 Horn relayrestored - Post148 Hornsrestored by horn works - Post170 Horn screwsoriginal zinc - Post413 Hose clamporiginal - Post365
I-K
Idler armoriginal #3917581 and seal #5693027 – before and after -Post 204 Ignitioncoil bracket original vs. Service replacement - Post413 Ignitioncoil comparison - Post492 Ignitionswitch - pick it when you have no key – Post1379 Innerfenders NOS - layout for A-Arm flaps - Post1020 Innerfenders NOS - drilling for stapling rubber shields & making staples – Post1045 Intakemanifold bolts shouldered and non-shouldered -Post 581 Intakeoriginal #3017610 restored - Post664 Intake oilfill tube cap - original vs. Service replacement -Post 369 Intakethermostat housing – Post37 Interiorbucket seat catch stops restored – Post1251 & 1261 Interiorcarpet installation front – Post735 Interiorcarpet original tag – Post4 Interiordoor panel fuzzies (NOS) vs. reproduction – Post1143 Interiordoor panel installation – Post1156 & 1157 Interiorlace vs. reproduction – Post1191 Interior(NOS) package tray #7666129 – Post1134 Interior pillarpost seals original – Post349 Interiorrear view mirror original restored – Post1140 Interiorsail panels re-glued and installed – Post1097 Interiorseat belts – original - Post1142 Interiorseat belts - original Model 137 vs. Model 177 – Post1183 Interiorseat rear - Al Knoch issues – Post1191 Interior seatrear - correct burlap and spring & view from trunk – Post1251 Interiorseat rear - correct original cover installed – Post1297 Interiorseat track hardware original restored – Post1191 Interiorsill plates (NOS) purchased 1979 with rivets – Post1191 & 1232 Interiorwindow - vent knob repair and put back on after chroming – Post1303 Judging BowTie results – Post1232 & 1238 Keys-Briggs& Stratton - Post304 & 1249 Kick panelsOER installed - Post709
L-M
Leaf springbushing - front #362108 - Post441 Leaf springcomparison original vs. reproduction and installed -Post 441 Leaf springhardware original -Post 402 & Post441 Leaf spring J-nutssafety issue - Post465 Leaf spring- rubber #3908370 for spring eye - Post186 & Post441 Leaf springshackle plates restored - Post442 Leaf springstampings - Post201 Licenselight fixture removed -Post 275 Licenselight fixture original restored vs. Service replacement - Post667 Mirror -rear view original and Paragon replacement -Post 214 Muncie shiftball with Knob (NOS) #3922525 – Post1138 Muncieshifter boot retainer ring screws – Post1077 Muncieshifter bracket original bolts installed – Post1408 Muncieshifter nuts with washers attach rods to transmission - Post748 & 750 Muncieshifter original Niagara orange cap -Post 378 Muncieshifter original handle re-chromed -Post 374 Muncieshifter rods BB vs. SBC - Post409 Muncieshifter with console (under cover) – Post1020 Muncieshifter with stabilizer bar (Note: there were 3 different stabilizer bars usedbetween engines and transmissions) -Post 385 & 409& 859 Moldingreveal – Post 1077
O-Q
Oil dipsticks ‘68Z two versions – Post1041 Oil filterPF-25 original with embossed bottom - Post328 Oil filterPF-25 and PF29 - Post666 Oil FilterPF-29 correct for 1968 - NOS vs. Repro – Post1312 Oil filterstenciling - Post677 & 680 Oil pandifferences original vs. Service replacement -Post 412 Oil panready to paint - Post472 Oil pansplash shield original round hole - Post412 Oil pressureline and fitting link to CRG – Post830 Oil pressureline fitting to block – original – Post845 Oil pressureline fitting installed - Post902 Oil pressureline routing – Post1020 Paint – 1ststep, Lonny washing to prepare for paint -Post 174 Paint – 2ndpictures of body after wet sand and buff -Post 289 & 290 Paint primersteps – Post 79,85 & 97 Paint Z/28stripes layout – Post1084 & 1087 Paint Z/28stripes original parts – Post3 & 963 Paint Z/28stripes painted on – Post1144 Parkinglight bulbs – Post1146 Parkinglight fender bezel -Post 373 Parkinglight grille original housing, lens, screws and gasket -Post 334 Parkinglight quarter panel installation and bolt up – Post1014 PCV -ventilation valve spun correct vs. Service replacement -Post 369 & Post633 Plasticscratch remover “Novus” - Post634 &639 Plugs rubberrear quarter original #4805844 -Post 419 and #4802102Post 590 Plugs rubberrear quarter original installed – Post979 Quarterwindow glass and seals original - Post596
R
Radiator capRC-15 original vs. reproduction -Post 369 Radiator capRC-15 original 68 and 69 restored - Post508 & 1098 Radiatorclutch fan stamped 11 2 67 SC -Post 258 Radiatorpetcock original ‘Weatherhead Company’ -Post 298 &1094 Radiator tagoriginal - Post202 & 1094 Radiospeaker AM front original -Post 578 Rag joint -‘68 original on left ‘67 Corvette right one - Post140 Rag jointrestored - Post163 Rally wheelDF showing two kinds font - Post430 & Post607 Rally wheelpaint #1403 Krylon dull aluminum to argent silver - Post 520 Rally wheelwith tire micro weights - Post285 & Post335 Rally wheelwith trim ring and centers (NOS) 1980 – Post1173 Rally wheelvalve stems - Post 566& Post 575 Rear 12 boltair vent - original vs. reproduction (nice) – Post819 Rear 12 boltbumper rubber and hardware installed -Post 442 Rear 12 boltstamping BV 1129 G1 - Post169 Rear 12 boldhardware - #3930052 cushion and installation -Post 445 Rear 12 boltring gear dated 11/67 and axles – Post116 Rear 12 boltU-bolts - Post 429& Post 441 Rear 12 boltyoke - Post 369,with like new slinger - Post 377 Rear glassinterior trim painted – Post979 Roger Deanemblem – Post 848 Rocker panelmolding (NOS) – Post 78 Rust PreventionMagic - Post 375
