Old 09-06-2020, 04:25 PM
We have you up north with the cold weather and Dave in Texas where it's too hot to paint. Extremes!
Old 09-06-2020, 05:41 PM
It's cool and overcast here today, but that's keeping me in the shop where more work will get done. Checked the rotors this morning and they are measuring 9.90 and 1.020. Good thing is that I have another pair of nice takeoffs that measure 1.010 and 1.030 that I can use. They are now off for a soak in the Evapo-rust tank and should come out looking like new before being re-used.
Old 09-07-2020, 07:26 PM
More of the mundane stuff while I restore the front brakes and rebuild the suspension. All of this has to be done ahead of the more exciting Day II parts as the car needs to become a roller again sometime before year end. Here are some more pics for those who like the original stuff being re-used, and a couple neat paint daub pics on the front calipers. Also seen here is a restamped build date for one of the calipers. I have not seen them restamped before but I'm sure it happened when parts sat around.
The one caliper was cast in July and assembly stamped 227, but must have sat around for months before being picked up for use since it was restamped 049 atop the 227. The other caliper was stamped 32 for an assembly date and was cast 361. Now that all of the rust has been removed, time to paint them up, install new o-rings & seals and lightly face/machine the rotors. All factory brakes for this car and no repro parts being used other than the soft lines.
Ready for a light surfacing.
Cleaned up in Evapo-rust
Dust shields and caliper brackets are now going out for plating.
This caliper had an nice daub or orange paint and both dust caps on the bleeders.
It was stamped 32 for an assembly code and was cast 361st day
This one was cast 207 and must have sat deep in the pile as it wasn't used until February...
It was first stamped 227 as it appears, and was then restamped 049 by the looks of its assembly stamp?
big gear head (09-07-2020)
  #174
Old 09-07-2020, 07:34 PM
While cleaning up the other parts, I also decided to restore a spare pair of low mile calipers I had sitting here as spares. They turned out to be pretty clean as the pistons show. Earlier today I then got around to pulling the front springs out and split the ball joints. Now I will tear down the control arms before painting them...and may install new hardware if I can find some nice original stuff.
big gear head (09-07-2020), cruiserofland (09-07-2020), X66 714 (09-07-2020)
  #175
Old 09-07-2020, 11:17 PM
It's all blown apart here. Tomorrow I will get the bushings pressed out and I guess I might as well media blast it and have everything powder coated and do it right. (lol)
Damien (09-07-2020), X66 714 (09-08-2020)
  #176
Old 09-09-2020, 01:54 PM
rlw68's Avatar
rlw68 rlw68 is offline
This is too cool !!! My calipers are RH casting# 204 with date restamped 48?, and LH casting# 355 date stamped 32. I thought one got replaced but maybe not now, given how close the build day is for our two cars.
Rob
The Following 2 Users Say Thank You to rlw68 For This Useful Post:
L78M22Rag (09-09-2020), NorCam (09-10-2020)
  #177
Old 09-09-2020, 04:54 PM
It's uncanny the similarities between these 2 cars built within a day of each other Rob. It's like the same batch of parts were being picked over by the same guys on the same lines, but a shift apart from each other. I take it there must have been a run of calipers dug out and re-stamped that particular week where they used whatever was left in old inventory? Maybe they ran short on production or they deliberately cleared out old stock. Cool to know for sure.
L78M22Rag (09-09-2020), rlw68 (09-09-2020)
  #178
Old 09-09-2020, 06:23 PM
That is some cool documentation of component dating right there! Thanks for sharing all your discoveries.
The Following User Says Thank You to L78M22Rag For This Useful Post:
NorCam (09-10-2020)
  #179
Old 09-09-2020, 06:58 PM
napa68 napa68 is online now
Looks great Graeme!
Old 09-10-2020, 01:50 AM
Thanks Tim.
Just popped out to see my bodyman / painter today and the plan is to get the car out to him next week. I have a couple options for the way the bodywork and paint can be handled, but that also determines the timeline in which it will be done. I have some decisions to make before the car is brought to him next week. The plan is to polish a couple spots on the original paint, and custom tint a match of the Daytona Yellow. He is 73 years old now and still going hard.
dykstra (09-22-2020), napa68 (09-10-2020), ScottG (09-20-2020), tom406 (09-11-2020), Tracker1 (09-10-2020), X66 714 (09-10-2020)
